Scangauge won't read EBP
Maybe two different xcodes for early/late models? I believe early build EBP can be bypassed with no issue because the turbo gets its parameters elseware.. Late models ebp is used in either "true" or default. I run my 05 with the ebp unplugged simply because I haven't had the time to order parts with no issue other than no turbo at normal idle
After reflash 06E17 the 03-04 trucks use inferred EBP, that is to say it no longer reads the sensor.
Here is some detailed info : https://www.ford-trucks.com/forums/1...l#post14911713
tunedportcj5
10-12-2004 08:56 AM
