Vibration/misfiring???
Old Dec 24, 2015 | 01:17 PM
Rickzap's Avatar
Rickzap
Ok guys, i am a little puzzled on this one. I have a 95 F 150 4x4 4.9 liter inline 6. Here is what i have done in the past week. New distributor cap, roter, wires, and plugs. Also, a new ignition coil and exhaust from the cat back. Truck starts up just fine but i start to get a pretty hard vibration at the top of second gear and beyond. The faster i go the more the vibration. I thought at first maybe it is misfiring but i am not sure. I also thought maybe it is u joints but i replaced the ones on the main drive shaft about 6 months ago so i have sort of ruled that out. I Dont know what to do. I pulled all of the plug wires one at a time while the truck was running and verified they were all getting spark to the plugs. Any suggestions? Thanks in advance.
Old Dec 24, 2015 | 02:41 PM
Filthy Beast's Avatar
Filthy Beast
The little guy is 15 years old....have you jacked up the front end and checked for loose tie rods/ball joints c bushings, steering column play, etc? I would still check your front u joints and drive shaft for being "in phase". How's the pinion gear/u joint?
Old Dec 24, 2015 | 11:14 PM
joey2fords's Avatar
joey2fords
even though you replaced the u-joints 6 months ago, they are still one of the very first things you should check.
i had a (non-ford) truck many years back that liked nothing better than to chew up a u-joint every few months. sold it before i ever figured out what was wrong with it.
65f100_352
1978 - 1996 Big Bronco
Mar 13, 2018 02:47 PM
mrmurph
Aug 8, 2014 02:04 PM
dieselsubmariner
26
Aug 17, 2013 09:15 PM
kevinwilly
Dec 22, 2009 08:58 PM
justin_brandstein
Dec 12, 2008 06:07 PM
