Steering stabilizer and HD & Custom difference
Old Dec 22, 2015 | 05:11 PM
Gooz's Avatar
Gooz
Is there a steering stabilizer for a 92 Ford F-250 custom 2wd? and what's the difference between a f250 custom and a f250 heavy duty?
Old Dec 22, 2015 | 05:37 PM
Ron94150's Avatar
Ron94150
A custom is just a stripped down, bare bones work truck. Not even a headliner. If your lucky you get a/c and maybe a radio. My dad bought a new 90 model custom when I was a kid. It had air, but had to have a radio installed. If it's straight shift, it will have the weaker m5od. The heavy duty is going to have beefier springs, if straight shift, a zf5, if auto a hd tranny cooler, and other things that someone else can chime in on. Probably a lower gear, higher capacity tires etc.. Why do you think you need a steering stabilizer for that truck? Any steering stabilizer should work, may have to fab a mounting bracket.
Old Dec 22, 2015 | 06:19 PM
Bird-Dog 250's Avatar
Bird-Dog 250
Does the truck wander? On roads that heavy truck traffic the road tends to have truck ruts. Does the truck follow these ruts in excess? Does the truck tend to drift more than you would like on the highway. More effort to keep it straight? This is what my truck does. It's a 4x4 7.3 extra cab long bed. So far I have done tie rods and ball joints along with a FEA. I still have the problems I've described. I'm thinking at 200K I need to replace the steering box and the rest of the stuff in the steering. I also question the tires. They are the right tires for the truck but come from CosCo. They were put on by the last owner for the sale of the truck. After a 1000 mile drive from NC to MA I was exhausted from wrestling with this issue. 2 FEA shops keep telling me all is ok but I drive the truck and know it is not right.
I don't know how different 2WD is from 4WD but I'd be currious as to what you do to fix the problem
Old Dec 23, 2015 | 08:05 PM
Gooz's Avatar
Gooz
Well I bout this truck for 2800 with only 71,000 miles on it. It has AC/Heater, it's a 5speed with cruise control, has a radio and even has a headliner. I saw it was a custom and thought it's not gonna be able to pull large trailers or even a car hauler. So I was just wondering if there's much difference between a HD And Custom.
And for the stabilizer part it keeps going into the ruts on the highways down here. And when I try holding it straight the ruts will still turn me into them. At one point I almost went into on coming traffic. So I was thinking a stabilizer would work. But idk where to get them from and preferably a dual stabilizer too.
Old Dec 23, 2015 | 08:25 PM
joey2fords's Avatar
joey2fords
as indicated, a custom is a bare-bones pickup ... however ... it could be ordered with all kinds of upgrades. for example, you have a/c ... that would be almost unheard of on a custom up here. you could very well have a suspension or rear-end upgrade ... or not. decoding your VIN might tell you more about your truck.
at only 71k miles one might THINK that the steering box should be ok ... but i would definitely take a look at it.
Old Dec 23, 2015 | 08:35 PM
danr1's Avatar
danr1
There is a Custom HD at least in the 8th generation, never seen LD in the 9th generation but hear tell there is such an animal.
Look at the sticker in the door jamb, if over 8500lbs GVWR it is heavy duty. As previously stated "Custom" is a trim package a basic no frills truck manual everything.
Far as the stabilizer a properly functioning front end does not need one, instead of buying one and installing it to mask underlying issues, use that money you'd spend on one to replace worn parts and a have an alignment done at a competent shop with good normal sized tires on it.
Only reason to install a steering stabilizer especially a dual model would be if you intend to run high speed on very large tires, doing so over very rough terrain such as baja racing type activity. Normal street stuff a well maintained front end/truck just doesn't need it, is a waste of money.
Replace any and all parts with play in them, ball joints piviot bushings tie rods ends worn parts in the steering shaft etc etc and so on. Once you do that and have it aligned you'll be surprised how nice it runs down the road.
Old Dec 23, 2015 | 09:59 PM
Nothing Special's Avatar
Nothing Special
danr1 was saying this, but to be clear, "Custom" is just a trim level. It could be on an F-150, an F-250, an F-250HD or an F-350. Trying to figure out the difference between Custom and F-250HD is kind of like trying to figure out the difference between XLT and F-150.
An F-250HD, regardless of trim level, is a 3/4 ton truck that's been upgraded (at the factory) with a full-floating rear axle, stiffer springs and often other parts of the running gear. As Ron94150 said (but incorrectly connected to Custom), a standard F-250 might have the same M5OD manual trans as a half ton truck while the F-250HD will have the same ZF5 trans as a 1 ton (even if it's a Custom).
And as danr1 said, a stabilizer isn't going to help you. You need to find and fix the real issues in your steering.
Old Dec 24, 2015 | 03:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Gearbox depends on engine.
A 460 will always have a ZF.
A 351 250 will have a ZF.
A 302 'LD' 250 will have a m5od and semi floating 10.25.
At least this is what I've seen.
My 'Custom' truck came with radio and headliner, vinyl bench and floor mat.
XL & XLT trucks have plush interiors, lighting & convenience packages, exterior trim and sometimes two-tone paint.
Old Dec 24, 2015 | 06:15 AM
Bird-Dog 250
Yes... check out the front end for wear before you throw money at it!
Old Dec 24, 2015 | 07:14 AM
Ron94150's Avatar
Ron94150
Your right. I should not have connected the m5od with the custom, as you can get all engine in a custom and all 351, 460, and diesels had the zf5.
Old Dec 24, 2015 | 07:24 AM
Ron94150's Avatar
Ron94150
Didn't know the custom was even available with a headliner. Never seen one, it is an option on the xl as well. My 94 xl does not have one. I would not call the xl interior plush though. All the xl's I've seen are still vinyl bench seats, manual Windows and locks, and rubber floors. Only options mine came with was a/c, cruise, radio, and e4od automatic. No door courtesy lights, and the door panels only cover top 2/3 of door.
Old Dec 24, 2015 | 07:55 AM
Nothing Special
At one point the higher trim levels really just came bundled with more niceties "standard", but you could still order most of them as options with a lower level. Back in '84 I ordered a brand new '85 F-250HD with XL trim (the second lowest), but I ordered it with all of the XLT comfort features except carpeting. That gave me the XLT I wanted except that I still had the easier to clean rubber floor mats. So what you find on a low level trim really depends on how it was ordered. Lots of Customs were strippers to keep the cost down on a fleet truck, but quite a few would have been upgraded as they were ordered.
Old Dec 24, 2015 | 12:24 PM
Gooz's Avatar
Gooz
Thank you guys I really appreciate all the answers and I'll go ahead and take my truck in for an alignment and fix the worn parts.
Teds
Dec 21, 2019 11:01 AM
svastano
Oct 15, 2017 09:15 PM
Gooz
Dec 22, 2015 05:11 PM
sparrish65492
Dec 21, 2011 01:14 AM
jovainc
Feb 13, 2007 07:56 PM
