2002 steering wondering left & right? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-12-2017, 08:34 PM
svastano
svastano is offline
svastano is starting off with a positive reputation.
Group,
Is there a common problem with the SuperDuty's having steering issues? As you drive down the road it wonders all over the road. you are constantly steering back and forth to keep it going strait. It drives me nuts, hate driving the truck! I have had ball joints replaced, track bar, tie rod ends. Truck only has 64k on it so I am stumped. my Mechanic says it is the steering box. Could it be something as simple as a front end alignment needing done? Steering stabilizer???
Thanks in advance.
Sam
Old 10-13-2017, 04:00 AM
seville009
seville009 is offline
seville009 is gaining momentum as a positive member of FTE.
Could be a simple alignment or bad/under inflated tires.....check your tire pressures, rotate your tires, snd get an alignment. Should take less than an hour and $100 at a tire shop and will hopefully solve your problems.
Old 10-13-2017, 04:52 AM
svastano
svastano is offline
Tires Have been checked for pressure, and rotated. They only have approx. 4,000 miles on them so relatively new. I think I will try the alignment first.
Old 10-13-2017, 05:51 AM
DogRidesInBack's Avatar
DogRidesInBack
DogRidesInBack is offline
DogRidesInBack is gaining momentum as a positive member of FTE.DogRidesInBack is gaining momentum as a positive member of FTE.
Could be the steering box, does the steering wheel have play?
Your new tires? Do they have directional strips or are they blocky? In general, tires with definite strips steer better.
The steering stabilizer helps with a feeling of stability, a worn stabilizer can give a sense of wandering. But I have usually felt other symptoms with that such as vibrations and wobbles; you did not mention those issues.
One truck I had running oversize BFG A/T wandered even after getting rid of all play and a good alignment. Had another alignment to add more caster than stock and it drove much better after that.
Old 10-13-2017, 07:38 AM
svastano
svastano is offline
Steering wheel does have some play. As for tires I have Goodyear wranglers, Blocky type. Steering stabilizer is relatively new last 3-4 years, but remember I have a 15 year old truck with only 64,xxx miles so not very many miles since new. I think I am going to try the alignment first.
Thanks for all the replies!
Old 10-15-2017, 08:36 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is online now
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
It's Ford's undersized and underpowered steering box/pump on these trucks. Swap it for a A1cardone
Old 10-15-2017, 08:43 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
My 03 is the same way and I also have replaced every part including the steering box with a Redhead box. I have grown to just live with it but it takes some time to get used to it after I drive my expedition which drives so nicely.
Old 10-15-2017, 09:15 PM
svastano
svastano is offline
Thanks I will look at both the Redhead box and the A1 cardone
pweng1
06-13-2017 11:46 AM
KCTDad
6.7L Power Stroke Diesel
02-17-2017 10:46 PM
Firefighter 1406
1997-2006 Expedition & Navigator
12-28-2016 08:34 AM
mikeceli
08-11-2016 05:48 PM
Gore0199
06-06-2016 08:25 AM
Quick Reply: 2002 steering wondering left & right?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
