$0.52 mod??
Old Dec 19, 2015 | 03:08 PM
SkySkiJason's Avatar
SkySkiJason
$0.52 mod??
So, after looking at Tugly's pic the other day I wondered if there was a way to address the problem of UVCH coming partially unplugged with $0.50 mod.
This is what I came up with.
Old Dec 19, 2015 | 03:09 PM
Jaime74656's Avatar
Jaime74656
any pics? nothing posted?
Old Dec 19, 2015 | 05:02 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You could always go with the $15.95 mod. I know it is pricey for what it does, but peace of mind is often priceless...
Amazon.com: Ford 2C3Z-14A163-AB - RETAINER: Automotive Amazon.com: Ford 2C3Z-14A163-AB - RETAINER: Automotive
Old Dec 19, 2015 | 05:10 PM
jhl3's Avatar
jhl3
I did not know about these.
Why are there three in that picture?
Old Dec 19, 2015 | 05:12 PM
Sous's Avatar
Sous
FTE Emeritus
Not sure, maybe just marketing that had no idea what they were taking a picture of. Pure Diesel has the same thing.
Ford 7.3L Updated UVC Harness Clips 2C3Z-14A163-AB
Old Dec 19, 2015 | 05:14 PM
jhl3's Avatar
jhl3
Super. Good info. Bookmarked.
Old Dec 19, 2015 | 06:38 PM
Dirtscooter250's Avatar
Dirtscooter250
Be careful with the quarter or retainer clip mod with updated Ford harnesses or international. They are upgraded and have short bridges to support the latch. I tried using the retainer clips but the bridges are in the way.
Old Dec 19, 2015 | 08:23 PM
F350-6's Avatar
F350-6
If you're that scared of the quarter, just clean and superglue the connection. The plug sliding loose 1/16" or 1/8" isn't going to affect the connection of the wiring. The connection isn't that high tech.
Old Dec 20, 2015 | 07:38 AM
SkySkiJason
Good info! I tried the quarter on those too and decided the better design mitigated the need for it. I can say I have never had a truck come back for VC gasket issues. I have done the $0.50 mod, new Ford/Int'l gaskets and UVCH's or my favorite for the last couple of years - the Dorman units with integrated UVCH's. And, the Dorman's have a lifetime warranty if one does fail.
I have always threatened to do that, but feared the superglue would not survive in this environment... I pictured little chunks of superglue falling into the oilpan.
Old Dec 20, 2015 | 09:43 AM
Tugly's Avatar
Tugly
There are Dorman VC gaskets with solid connections to the UVCH - no plug and jack. I have no direct experience with these, but I hear good things - it's worth a little homework before making the call.
I had a "noisy" connection when I had the problem in question:
I bought new OEM UVCHs, and the fit was very tight. As time rolled on and I kept popping VCs, even the new OEM connections started getting a little sloppy and I had to do the 50-cent mod to tighten things back up. I suspect I have a set of Dormans in my future.
Scott bought new OEM VC gaskets, and the outer connectors were too sloppy to use. We can't seem to win here.
Old Dec 20, 2015 | 09:50 AM
dn29626's Avatar
dn29626
Title .50 vs .52 cent mod? What am I overlooking in this post?
Old Dec 20, 2015 | 10:41 AM
Rikster-7700's Avatar
Rikster-7700
I believe it is the tie wrap in the original picture? If it's not then I am lost as you...............
Old Dec 20, 2015 | 11:16 AM
scotttahoe's Avatar
scotttahoe
I bought 2 brand new ones as Rich mentioned and was dumb founded at how bad it was. Brand new international gasket too. We had to put the old one back on which clipped in nicely and had nothing wrong with them as they were only 2-3 years old, bought new OEM just for a piece of mind.
Old Dec 20, 2015 | 01:23 PM
Sous's Avatar
Sous
FTE Emeritus
Dorman UVCH all in one linked below.
https://www.rockauto.com/catalog/mor...nid=577&jpid=5
Old Dec 20, 2015 | 02:41 PM
SkySkiJason
Yes, I added zip ties. It is a FIRM connection now and I don't think what happened in Tugly's pic can happen with these.
Figured the zip ties are ~$0.01 each!
