MORE EBP PROBLEMS
Old Dec 19, 2015 | 11:57 AM
Jforce05's Avatar
Jforce05
Could be true but still doesn't explain why i have a turbo hiss at idle on cold start then cuts out after 45 seconds
Old Dec 19, 2015 | 12:05 PM
Maxium4x4's Avatar
Maxium4x4
The VGT cycles, now about your intake filter, you have a few codes.
Old Dec 19, 2015 | 12:07 PM
Jforce05's Avatar
Jforce05
K&n filter and elbow. Crap for these trucks i know. Was planning on replacing the filter with an s&b drop in and keeping the elbow
Old Dec 19, 2015 | 12:18 PM
Maxium4x4's Avatar
Maxium4x4
The 6.0L is fly by wire, you need to address the problem because the engine is not seeing the proper intake readings.
Old Dec 19, 2015 | 01:30 PM
Jforce05's Avatar
Jforce05
So are you thinking the restriction at the air filter is the cause for the turbo hiss dropping at idle and the consistent low ebp numbers?
Old Dec 19, 2015 | 02:08 PM
Maxium4x4's Avatar
Maxium4x4
No you have codes for the MAF and IAT that need to be addressed because of the K&N filter, assuming. A stock filter is good up to 500HP and I use a stock filter with 426HP.
Old Dec 19, 2015 | 02:30 PM
Jforce05's Avatar
Jforce05
Im guessing i am close to 500hp as is sits
Old Dec 19, 2015 | 10:32 PM
Maxium4x4's Avatar
Maxium4x4
You would have to have extensive upgrades to hit 500 at the rear wheels and without a dyno run, it would be a guess. Correct the items one by one because everything the sensors see adjust the engine management.
GR8Dane
6.7L Power Stroke Diesel
Dec 9, 2017 11:31 AM
McBusiness11
May 10, 2017 03:03 AM
austinpowerz101
Oct 5, 2011 05:05 PM
High Binder
Jul 13, 2011 10:18 AM
Stroker 94 1/2
17
Sep 5, 2007 07:24 PM
