Turbo Flutter or Surge on Idle? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 12-07-2017, 12:42 AM
GR8Dane's Avatar
GR8Dane
GR8Dane is offline
GR8Dane is starting off with a positive reputation.
Hey guys.
I'm getting some turbo flutter or surge when my truck is at idle. Been going on a for a few months and it's getting really obnoxious. Usually the truck needs to be warmed up a little for it to happen, but it's pretty consistent all the time now, (see the video below).
I've got about 104,000 miles on the truck, no performance mods or tunes. I did have a friend replace my cracked exhaust manifolds and studs last November. We inspected the turbo and found a some play in the bearing and went ahead and swapped the turbo for a new stock turbo at the same time. I didn't have this issue before the new turbo or for the first 6 months of this turbo, but it's been happening the last 5 or 6 months now.
I'm thinking the truck is making just a little boost at idle, so I'm considering adjusting the wastegate. Can anyone confirm if that is the right approach? If so, how do I determine how much to adjust? Pretty sure the turbo needs to come off to adjust the wastegate, so I want to get it right the first time if possible. Not sure if it helps, but I still have my original turbo for comparison.
Thanks!
Old 12-07-2017, 03:16 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
EpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant future
It sounds like the truck is snoring. I'm interested to hear what others say. Just to confirm, the flutter happens on idle, not on acceleration? You can hear the turbo spinning quietly and then the flutter? It does sound like the waste gate is overly sensitive.
Old 12-08-2017, 07:29 PM
cangim's Avatar
cangim
cangim is offline
cangim has a good reputation on FTE.cangim has a good reputation on FTE.cangim has a good reputation on FTE.
I am curious as well... Sounds like vanes close to spool then dumps it all. Do you have ability to read vane position?
Old 12-09-2017, 12:28 AM
GR8Dane's Avatar
GR8Dane
GR8Dane is offline
My friend brought over his SnapOn scan tool and I don't think we were ever able to see the vane position. I'm not sure there is a PID for that. We were kind of wondering the same thing, but I'm more and more convinced that the wastegate just needs a little adjustment. My friend is going to see if there is a factory recommendation for the adjustment we can try.
Really strange issue though.
Old 12-09-2017, 06:48 AM
senix's Avatar
senix
senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
see the TSB and see if that fits your issue.
File Type: pdf
Old 12-09-2017, 11:31 AM
cappa
cappa is offline
cappa is gaining momentum as a positive member of FTE.
On my monitor on a 15 it is vgtdc%. As in variable geometry turbo duty cycle
Ebercoatings
New Member Introductions
01-12-2018 10:37 PM
Anthony Giovino
Ford Truck Parts for Sale
04-15-2017 07:50 AM
Michael Sawatsky
07-14-2016 11:46 AM
FoxClubNiner
04-29-2016 06:50 AM
Macrobb
48
03-05-2016 11:55 PM
Quick Reply: Turbo Flutter or Surge on Idle?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
