EBPV question
Old Dec 18, 2015 | 05:47 PM
bandlgeorge's Avatar
bandlgeorge
EBPV question
Hi guys. Any idea why my EBPV would oscillate like this instead of a steady hiss like it should have?
Old Dec 18, 2015 | 07:08 PM
jhl3's Avatar
jhl3
When is the last time that you cleaned your EBP tube and sensor?
Do you have any way of monitoring Boost, MAP, EBP at KOEO and then again at KOER?
The truck in my sig goes on and off at idle, just not as rapidly as yours.
Old Dec 19, 2015 | 12:30 AM
bandlgeorge
Been awhile since I've cleaned EBP sensor. Have boost gauge and EGT. No other gauges.
Old Dec 19, 2015 | 07:02 AM
jhl3's Avatar
jhl3
There was a recent post that will help you get the remainder of the readings that you need to help diagnose problems, with the exception of fuel pressure.
Link:https://www.ford-trucks.com/forums/1...e-cheap-3.html
Good stuff!
Old Dec 19, 2015 | 09:02 AM
Tugly's Avatar
Tugly
If the idle is low enough, the low oil pressure isn't quite high enough to keep the EBPV closed tight. Once the idle kicks up, it should keep it from cycling. If your high-idle is going and the cycling still occurs, this could be the EBP sensor, the EBPV, your oil pump, the oil pickup seal, or the PCM is "on the verge" of shutting the EBPV off.
Old Dec 19, 2015 | 10:56 AM
bandlgeorge
The idle is high enough I think. It does the high idle that shuts off when I step on the brake to shift into gear. I should have added that some days it does perform as it should. I'll look into the sensor and cleaning and rule those out and go from there.
Shaun Fed
6.4L Power Stroke Diesel
Jul 25, 2019 05:12 PM
genscripter
May 9, 2014 01:33 PM
Izzy351
Sep 28, 2007 02:47 PM
watermanh
Jul 6, 2006 11:59 AM
Geoff Brown
21
Apr 27, 2006 12:25 AM
