Sliding rear window installation
Old Dec 18, 2015 | 12:45 PM
GeneGregory's Avatar
GeneGregory
I am going to take out the sliding rear window in my truck and put it back in with a new weatherstrip / rubber seal. Should I use a sealer along with the new rubber seal ? what type of sealer ? where does it go ? between the rubber and the body sheet metal ?
Old Dec 18, 2015 | 02:28 PM
51fordf5's Avatar
51fordf5
You shouldn't need to use any other type of sealant with the rear window seal. I didn't use any when I replaced mine a year and a half ago and it's been fine. The window seal fits very tightly and does the job of sealing on it's own.
Old Dec 18, 2015 | 03:13 PM
privateer, eh's Avatar
privateer, eh
If you use soapy water when you reinstall your window you should'nt need any sealant. Dawn and Palmolive soap should do just fine.
Old Dec 18, 2015 | 03:43 PM
winginit's Avatar
winginit
What do you do, just soap it up good and push the window into the cab ? Thanks
Old Dec 18, 2015 | 03:52 PM
GeneGregory
Thats what I was thinking, but I had a new windshield put in and the installer used a sealer along with the new weatherstrip and windsheld. My wife and I have done these before in older trucks we soap them up she pushes while I pull the cord on the inside.
Old Dec 18, 2015 | 04:53 PM
bradphx's Avatar
bradphx
Soap it up. Put rope in the seal. Do it so the ends of the rope meet at the bottom of the window. Set the bottom in. Then have another person push from the outside while you pull the rope which will pull the seal to the inside of the truck securing the window in place. Do a little on the left. Then the right. Keep switching back and forth until your done.
Old Dec 19, 2015 | 09:29 AM
maytea's Avatar
maytea
I need to do this as well...
Any tricks to getting out the old seal or best new seal to use
abyars111
16
Jul 21, 2015 06:55 PM
vermillion95xl
Jan 15, 2014 07:09 AM
yankeerebel
May 2, 2010 03:51 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Nov 27, 2008 11:36 PM
jetjock16
Oct 29, 2005 11:50 AM
