'93 transfer case light switch
Old Dec 17, 2015 | 10:13 AM
bf5113x's Avatar
bf5113x
Question '93 transfer case light switch
My '93 f150's 4x4 dash light no longer lights up when I switch into 4 wheel drive. I opened the dash and replaced the light bulb but that didn't fix the problem. I'm now trying to test the switch on the transfer case but having no luck getting ohm meter leads on recessed switch pins to check the switch its self. Can I unscrew the switch from the transfer case without having problems - like transfer case lubricant leaking from the opening once I remove the switch?
Old Dec 17, 2015 | 10:39 AM
bashby's Avatar
bashby
I dont think it will leak more than a couple drops. It is higher than the fill plug, isnt it? It might be easier to jump the connector terminals on the harness side and see if the light comes on.
Old Dec 18, 2015 | 07:49 PM
madpogue's Avatar
madpogue
Um, put wires with alligator clips on the switch terminals. Clip wires to meter probes.
And +1 above; jumper connector to test the rest of the circuit.
Old Dec 18, 2015 | 07:58 PM
bf5113x's Avatar
bf5113x
To madpogue - Already tried mini alligator clips, but terminals are severely recessed and only had room in opening for 1 alligator clip on one terminal. Thanks anyway.
Old Dec 18, 2015 | 08:53 PM
madpogue's Avatar
madpogue
Another option - if you can get your hands on a pigtail connector for the switch from a junked truck, cut it off, and use it as an extension connector for the meter. Or maybe you can buy the pigtail online.
Old Dec 19, 2015 | 07:01 AM
subford's Avatar
subford
Do you have Mechanical Shift or Electronic Shift?
Old Dec 19, 2015 | 07:54 PM
PRIMERED79 SHORT BED's Avatar
Is there only one switch for 4wd? I ask cause my light for 4 low works but 4 high doesn't, and I'm pretty sure the bulb is good.
Old Dec 19, 2015 | 08:39 PM
madpogue's Avatar
madpogue
IIRC it's one part. One wire is for the 4x4 light and the other is for the LOW RANGE light, and they both complete the circuit by grounding through the t-case case.
Oh, come to think of it, that means the OP should NOT jumper the wires as suggested above. Also it wouldn't do any good to ohm check between the two terminals, since they're separate circuits. The ohm check would be from each terminal, separately, to ground. Sorry, my EVTM is buried under a bunch of other stuff in the truck, otherwise I'd dig it out for the wire colors and terminal positions.
Old Dec 19, 2015 | 09:30 PM
How does it know which range its in if two wires go to one switch?
I'm asking cause I really dont know.
Old Dec 19, 2015 | 10:10 PM
madpogue's Avatar
madpogue
It's a double-throw (or is it double-pole?...) switch. It's in effect two switches in one part. When you shift to 4HI, one of the wires grounds to the case, which turns on the 4X4 light. When you shift to 4LO, both wires ground to the case, which turns on both the 4X4 and LOW RANGE lights.
Old Dec 20, 2015 | 07:28 AM
bashby's Avatar
bashby
I thought there were two switches.
Old Dec 20, 2015 | 07:35 AM
subford's Avatar
subford
He has not come back and said if he has a Mechanical Shift or Electronic Shift as I asked in post #6 above.
When he does I will post a wiring diagram that may help him.
They are not wired the same for the lamps in the cluster.
Old Dec 20, 2015 | 08:37 AM
Subford can you post one for mechanical?
Old Dec 20, 2015 | 09:06 AM
subford's Avatar
subford
Sure:
Old Dec 20, 2015 | 09:09 AM
bashby's Avatar
bashby
Ok it is one switch. So the easiest test would be to ground each terminal where the harness plugs into the swuch and see if the lights come on. If th ey do your switch is bad.
87thhunter
Jul 14, 2014 04:21 PM
PaulC
Jun 22, 2005 11:38 PM
sawdust220
Dec 31, 2004 08:40 PM
grogant
1978 - 1996 Big Bronco
Dec 9, 2003 11:39 AM
rickfitz
Oct 2, 2003 12:40 PM
