Second Towing Thread - please explain
Old Dec 17, 2015 | 06:59 AM
wojowojo16's Avatar
wojowojo16
PLEASE explain something to me..
2016 Ford F-150 Full Size Pickup Truck | Towing Specifications | Ford.com
According to this link, a 2016 F150 Supercrew Ecoboost (3.5) with 157" wheelbase can tow 10600 (with both 3.31 OR 3.55) OR 11600 (with 3.55), but there is NO differentiation between the 10600 and 11600 with 3.55 gears. I'm ASSUMING it has to do with the max trailer tow package, but that doesn't buy you anything you can't get by specking 3.55 with the regular tow package (and brake controller, etc). Am I completely missing something here??????
Old Dec 17, 2015 | 07:55 AM
seventyseven250's Avatar
seventyseven250
They do show those with different GVW numbers, 16,100 and 17,100. I Suspect the order guide or a Frantz could decipher that for you, but maybe it's the "max tow" that gives you a higher payload rating? I am used to seeing a footnote for situations like this, and I agree, it's not clearly spelled out.
Old Dec 17, 2015 | 08:25 AM
Tom's Avatar
Tom
It's the Max Tow package, but it's a little misleading the way it's listed on that site. Attached is the relevant page from the 2016 towing guide, and you'll see the footnote clarifying the higher GCWR is for the Max Tow pacakge.
The max tow package includes some things not available on the regular tow package. Of particular note is the upgraded receiver hitch that's rated for 12,500 lbs.
Originally Posted by 2016 F150 Order Guide
MAX TRAILER TOW PACKAGE (53C)
Usage: Max towing capability 12,200 lbs.
Availability:
● Optional on XL, XLT, Lariat, King Ranch® and Platinum
Not available with:
● 2.7L V6 EcoBoost® Payload Package (622)
Requires:
● 3.5L EcoBoost® Engine (99G)
Includes:
● 3.55 Electronic-locking rear axle (axle is changed to 3.73 Electronic-locking differential if
ordered with Heavy-Duty Payload Pkg. (627))
● 4-pin/7-pin wiring harness
● Auxiliary transmission oil cooler
● Class IV trailer hitch receiver
● Pro Trailer Backup Assist (47E) with Tailgate LED (optional on XL Base)
● Smart Trailer Tow Connector (standard on Lariat and higher)
● Integrated Trailer Brake Controller
● Upgraded front stabilizer bar
● Upgraded rear bumper
File Type: pdf
Old Dec 17, 2015 | 09:16 AM
wojowojo16's Avatar
wojowojo16
Tom, thank you! They need a *** that says requires Max Trailer Tow Package. ON another note with the trailer tow package, if 3.31 and 3.55 have the same tow rating, I don't see the benefit of 3.55....
Old Dec 17, 2015 | 10:39 AM
seventyseven250
It's a little bit of an apples-to-oranges comparison, but I towed a 7000lb travel trailer all through the mountains around here with no issues with the 3.31 gears. I did find it dropped down one or two gears more often than I was used to, so maybe with 3.55's you'd stay one gear higher? Anyway, it tugged plenty hard, so for me, I'd probably take the 3.31's again.
Now if you were towing every single day for commercial reasons, and over 10k often, seems like the deeper gears couldn't hurt you. But for most of us weekend warriors, I think 3.31 is the best all around gear.
Old Dec 17, 2015 | 10:46 AM
Tom's Avatar
Tom
I don't see the advantage to 3.55s either. I test drove one with 3.31s and accidentally left a strip of rubber up the on-ramp all the way through second gear.
Unfortunately the deal was there on a truck with 3.55s, and I'm perfectly happy with it. Wouldn't mind some lower cruising RPMs and the accompanying fuel economy bump.
Old Dec 17, 2015 | 10:54 AM
wojowojo16's Avatar
wojowojo16
I just looked at the 2015 F150 guide, at the very end, under tech specs for conventional towing, it says 11600 with a "little" 4 to the right, and 4 says requires max tow....they have it buried.
https://www.google.com/url?sa=t&rct=...mfvZACupYrzDsQ
Old Dec 17, 2015 | 11:37 AM
Frantz's Avatar
Frantz
Today's trucks are simply overkill for what we normal folks use them for. 3.31 axles are the way to go unless you specifically need higher ratios for what you're towing, or if you want to have more fun at stop lights.
Old Dec 18, 2015 | 02:08 PM
Tnriverside's Avatar
Tnriverside
I did drive a 3.55 and a 3.31 back to back. Both with 3.5 EB and similar equipment. To me the 3.31 was not as responsive as the 3.55. I did like the 3.55 better.
dooger54
All Things Towing
Apr 9, 2020 11:24 AM
PAWZ Guitar Company
2015 - 2020 F150
Jul 20, 2018 10:23 PM
dwk7
2015 - 2020 F150
15
Jul 19, 2018 05:22 PM
SJMaye
2015 - 2020 F150
18
Mar 2, 2018 08:24 AM
69_bronco
2009 - 2014 F150
Dec 30, 2011 10:33 PM
