Sponsored by: Real Truck
Fog lights
Old Dec 15, 2015 | 09:19 PM
badgerfan's Avatar
badgerfan
Fog lights
So ,tried finding the answer, but couldn't,
Have an 08 f350 xl and was looking to put oem foglights into the bumper where mine has the block out 's, guess what I am asking is if the wiring is already there as it was on a different vehicle I owned ,basically it was a plug and play ,have only had the truck for a week and with the hours I'm working I really haven't had a chance to crawl under and look for the wiring.
Thank you ,Ken
Old Dec 16, 2015 | 12:03 AM
Mike189677's Avatar
Mike189677
You should just need the the wiring harness that plugs in to the existing wires the lights and the headlight switch that matches all your current head light settings plus the foglight position. I have the part number if you need it for the harness for your year I found it the other day when I was trying to find the harness for my truck to add fogs and use the factory setup.
Old Dec 16, 2015 | 04:14 PM
Pit Crew's Avatar
Pit Crew
I would like to do the same thing. But I would rather wire to an upfitter switch instead of headlight switch. Can I just get the lights and wire harness minus the headlight switch?
Old Dec 16, 2015 | 09:37 PM
Mike189677's Avatar
Mike189677
You should be able to get the foglights and 9145 connectors summit has some Pico Wiring Connector Pigtails 5461PT - Free Shipping on Orders Over $99 at Summit Racing but I'm sure they are all over the interweb and then you can just wire them up to power and the appropriate upfitter switch.
Dmntxn77
Apr 24, 2020 09:27 AM
BradFilly
May 14, 2019 11:52 AM
wrdabney
Dec 27, 2016 08:08 PM
n3wpv
Sep 9, 2016 09:18 AM
Sport45
Feb 25, 2006 07:11 PM
