F-250 XLT fog lamps and light switch
I bought a 2016 F250 without fog lights and the headlights do not come on automatically. Ive found out that I need a new Factory selector switch, the wire harness, and fuse to install the factory fog lights. I want to add the automatic light control to my truck as well. What do I need to make it work?
on
If your lucky the wiring harness is in place already for the fogs. Head to the auto wrecker and buy a headlight switch with the foglight switch in it. Pick up a pair of foglights with the short wiring that plugs into the harness while you are there and your done. I have done this on 06 and 08 XLT trucks. Its been plug n play. I don't know anything about the auto daytime lights. I am up in Canada and our trucks come with those.
https://docs.google.com/spreadsheets...AtI/edit#gid=0
Sorry, old thread but...
Does anything need to be done for the fog lights to be activated ? I installed fogs (w new switch) on my 2014 xlt which already had the light sensor. I enabled bambi mode as well but now my dash lights don't come on. Only the gauge needles are lit when lights are off, and the needles go dark when I switch on headlights
The dash lights itself stay off.
The headlights and foglights do work however.
I used forscan. I might have screwed something up. ? Will reverse from the backup I have I guess.
When I use the dash light dimmer (next to switch) I do see the dome light come on when I switch it all the way up. Weird problem.
Supercab
05-23-2015 02:49 PM
