Checking in
Old Dec 29, 2015 | 09:19 PM
  #31
run6.0run's Avatar
run6.0run
Those are hpop fasteners. The stc kit does come with new ones. Do you remember putting the 2-8mm's in the discharge fitting (the stc fitting)???
Old Dec 29, 2015 | 09:51 PM
  #32
yellowfeverford's Avatar
yellowfeverford
Yeah I'm sure I put 5 bolts total for the hpop. Any idea if there is supposed to be a bracket or washers with the bolts for the FICM mount closest to the firewall. Front mount has studs, but when I took the FICM off, there was nothing holding it to the back bracket. I can reuse my old hpop bolts and maybe a couple fender washers?
Old Jan 1, 2016 | 07:13 PM
  #33
yellowfeverford
All done!!
I pulled the FICM relay and cycled the key engine off several times, cranked it 3 times for 15 seconds with a beer break between each crank. Plugged the relay back in and two crank, no smoke out of the tailpipe it started up.
Thank to everyone that took time to help me with my first diesel project.
I can't wait to do head studs.
Old Jan 6, 2016 | 08:27 PM
  #34
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Rock on, glad you got it going
DieselNewbie1
41
Sep 23, 2015 06:41 AM
oxt127
Oct 31, 2014 06:33 AM
locknload223
Apr 26, 2011 05:23 PM
Goobzilla
13
Jan 10, 2010 09:06 AM
Sheldon Plankton
15
Oct 27, 2009 05:57 PM
