Sponsored by: Auxito
Brighter headlights?
Old Dec 13, 2015 | 07:14 AM
Wayne J's Avatar
Wayne J
I have an early 1997 f150 (mfg. 3/96). The headlights are the typical yellow/cloudy. I know I can replace these units with new ones. However my wife has a 2014 Ford Escape. This thing has the brightest headlights of any vehicle I've ever driven. Is there some replacement unit out there that will give my truck the same quality of light as the Escape?
Thanks,
Wayne
Old Dec 13, 2015 | 09:21 AM
Kalinedrive's Avatar
Kalinedrive
Hi Wayne...I have the same model and early year f150 you have. I just bought it 3 months ago and have been making upgrades like replacing exhaust and removing rust. The headlights used to be yellow and clouding like yours. I looked for replacements lights but the early 97's have a different headlight than the late 97's. I ended up using the "3M 39008 Headlight Lens Restoration System." I was pleasantly surprised. It cleared them up. I can now see the road at night! Now, it will not be as bright as a 2014 Escape. But it does make a huge difference on the original. If I could find a replacement I would probably do that. But right now, I don't see anything out there.
Old Dec 13, 2015 | 01:11 PM
whomrig's Avatar
whomrig
I have a 2000 F-150 and I used toothpaste to clean my headlights.
The rag was damp seemed to work just fine, lots of yellow stuff came off.
Wayne
Old Dec 13, 2015 | 03:49 PM
blupupher's Avatar
blupupher
Does the Escape have HID headlights?
If so you will never get your trucks headlights that bright unless you do a HID retrofit.
If you want a decent upgrade, you can get some clear lens housings and some decent bulbs, but none are available for your year model. You can get them to work, but you would need to replace the header panel with a later model.
Cheapest option is to get a headlight cleaning kit and see what you can do with your current lights and get some new bulbs. Won't be as bright as the Escape, but will be better.
Old Dec 13, 2015 | 06:14 PM
rsylvstr's Avatar
rsylvstr
Bought these and the fogs many years ago. Much cheaper now. Work great with the brightest sylvania bulbs. No conversion kits or electrical stuff. Plug and play. Compliments all the time.
http://m.ebay.com/itm/DEPO-330-1115L-AS-Ford-F150-250-Headlight-Assembly-w-Lighting-Model-NEW-s-34-2-/320926598567?nav=SEARCH
Old Dec 13, 2015 | 07:13 PM
blupupher's Avatar
blupupher
Those won't work since his truck is built before 7/96. Those built before that time have a different mounting system and assembly. That is why I mentioned having to replace the header panel if they wanted to get clear headlights.
Old Dec 13, 2015 | 07:46 PM
rsylvstr's Avatar
rsylvstr
Was wondering. So does he look for 1996 parts or ???
I used Meguirs Scratch x on some headlights. Works well.
Old Dec 13, 2015 | 08:03 PM
blupupher's Avatar
blupupher
They just need to find lights designed for the pre 7/96 build date, but it is still listed under '97. They are out there, just harder to find.
Only ones are the OEM fluted type housing though, no clear lightning style.
Old Dec 14, 2015 | 11:44 AM
rsylvstr's Avatar
rsylvstr
I went through that with a Mitsubishi Galant. Drove me nuts
Old Dec 16, 2015 | 08:08 PM
steve(ill)'s Avatar
steve(ill)
how is the "they don't fit" fixed ? You say they have a different mounting bracket. Is this something a weekend mechanic could "MODIFY" and make fit or is it really a "DONT FIT" situation... Why would FORD make major changes in a light mount?
I understand you can BUY the header panel, but can yours be modified ??
Old Dec 17, 2015 | 10:44 AM
blupupher's Avatar
blupupher
No idea on if the pre 7/96 header can be modified, I just know replacement "fixes" the issue. I have never actually seen an early model headlight housing, so don't know what would be required to modify vs replace the header.
Also no idea why Ford made the change, but would guess it was a cost and/or tooling issue. The lights look the same from the front, use the same bulbs and have similar output (when new) to the newer design, just different mounting.
Old Dec 17, 2015 | 11:04 AM
rsylvstr's Avatar
rsylvstr
Gorilla tape should hold them
Old Dec 17, 2015 | 09:49 PM
steve(ill)'s Avatar
steve(ill)
I had a 1978 Supercab that had bucket seats from a 1976 Chrysler and I looked and sat GREAT !!.......... If I had a 1997 F150 and needed LIGHTS, I would buy NEW 1998- 2003 aftermarket and INSTALL them..... cant be that hard.
Gousetis
22
Oct 6, 2020 12:45 PM
ugh3012
Jul 18, 2016 07:59 AM
Icthus in AK
6.7L Power Stroke Diesel
32
Nov 3, 2014 07:31 PM
handifletch
Modular V10 (6.8l)
Oct 30, 2013 12:39 AM
stevenn1
Nov 6, 2006 11:29 PM
