Oil in tailpipe
Old Dec 9, 2015 | 10:09 AM
axelgawn's Avatar
axelgawn
Oil in tailpipe
Hey guys,
So I noticed my truck was running a couple quarts low and it whines right when you first start it up. I put more oil back in it but since its not leaving puddles I am thinking its burning it off. This didn't start happening until the weather got colder. After I floor it few times in park or Neutral the whine stops. Later I noticed some black stuff and oil coming out of the tail pipe. This also only happens I believe when cold starting. Now there is no smoke or oil spotting the ground. The truck does lack power but I figured it did not have much originally so this is to be expected. What do you guys think it is? Is there anything I can do?
Old Dec 9, 2015 | 01:20 PM
mountain dewd's Avatar
mountain dewd
What kind of whine are we talking about?
Old Dec 9, 2015 | 02:01 PM
Filthy Beast's Avatar
Filthy Beast
It's a grey Reisling...and stops flowing after a mashed pedal warmup 'cause the alcohol condensation has dissolved.
Or it could be cold / shrunk valve seals....or just the condensation picking up the carbon black from the exhaust pipes and dripping out....
Old Dec 11, 2015 | 09:18 AM
axelgawn's Avatar
axelgawn
The reason I initially said oil is because in 8 months of ownership it has burned through 3 out of 5 factory oil capacity. I had to put almost 4 quarts in it Saturday. Now the oil is caked on the oil pan but there is so oil on the ground, or spots anywhere else. So I am not sure what it could be. Also the tail pipe does not have any blue smoke or smoke of any kind for that matter.
ShellCaseyng
Jul 13, 2013 09:25 AM
Hematite
2004 - 2008 F150
Oct 11, 2009 01:11 PM
jjed2007
Oil & Lubrication
15
Feb 24, 2008 11:34 PM
DD1684
May 15, 2005 10:20 PM
Jimmy Dean
28
Nov 29, 2003 05:46 PM
