oil pressure problem PLEASE HELP
Old Jul 12, 2013 | 09:07 PM
ShellCaseyng's Avatar
ShellCaseyng
i have a 2000 7.3 and the other day i was driving and it started running terrible so i pulled over and cut it off. got out and checked the oil and the dipstick was bone dry. wouldn't start after that. towed it to my house drained the little bit of oil and replaced the oil filter and added new oil still wont start. checked HPOP and it was bone dry also. tryed filling it with oil and still no start. also i get no movement from oil gauge on dash and do get white smoke from tail pipe. please help
Old Jul 12, 2013 | 09:23 PM
snakedoc's Avatar
snakedoc
Well the rule of thumb for smoke is:
Black- poorly burning fuel
Blue/grey- oil
White- unburnt fuel or steam
if you HPOP will not stay full your LPOP may have dead or the pickup tube is bad.
Old Jul 12, 2013 | 10:40 PM
carltonwebb's Avatar
carltonwebb
If you are getting white smoke, injectors are trying to fire. You might try to unplug the icp and see if it will help it to crank.
Old Jul 13, 2013 | 09:19 AM
ShellCaseyng
ok i will do that. thanks but i should also mention that on my initial inspection the oil pan underneath was covered in oil and also oil was present under HPOP and in the valley. is it commoN for oil to leak at bottom HPOP
Old Jul 13, 2013 | 09:25 AM
snakedoc's Avatar
snakedoc
the hpop can leak for any one of it plugs. there is one on th bottom of the pump that can leak. here are some pdf of the pump
File Type: pdf
File Type: pdf
axelgawn
Dec 11, 2015 09:18 AM
hiredgun18
26
Sep 24, 2010 09:37 AM
77FordTruckMan
Nov 9, 2008 07:09 PM
dustan52
32
Jun 25, 2008 10:36 PM
DD1684
May 15, 2005 10:20 PM
