i know this has been a topic before but my truck has none of the symptoms described. it flashes but at no certain time or any particular instance. it dont happen everyday only occasionally. transmission was rebuilt with heavy duty clutches torque converter and towing shift kit and has 70k miles. this has been going on for a month. fluid is not getting hot running around 130 degrees with 2 large coolers only code it threw was tcc solenoid "slip greater than expected". changed the solenoid and shift solenoids and still flashing. havent made it to a scan tool since i replaced the parts and plan to just didnt know if anyone had any ideas. it does not shift differently or act out of the ordinary while light flashes. trans has been serviced at time of solenoid replacement about 400 miles ago. kind of annoying and would like to solve the issue if anyone has any input all would be appreciated.
