Cracked Piston or Dead injector?
Old Dec 5, 2015 | 11:58 PM
Alec Blanchard's Avatar
Alec Blanchard
This is gonna be a handful,but here I go anyways. On my 96, I recently did the UVCHs, gaskets, and pigtails. I hooked up a wire wrong and the number 7 injector wasn't firing. Went back and changed it, and nothing happened. Is it possible that I killed an injector, as it was injecting on the exhaust stroke or intake? Totaly the wrong time for fuel to enter the system... it's got 307030 kms, I believe that's near 190xxx miles. Anywho, is it past it's time of death? If they it is dead and I can't find a cheap replacement, I'll save up for stage 3s, an s468 and supporting mods. If not, what can I do to "revive" the injector? It vibrates between 1000rpm and 1700 rpm ONLY UNDER LOAD like in 4th and 5th gears. Idles rough too. Also, I ran er low on oil like 2 days before I did the gaskets, is it possible that starving it from oil can kill it or maybe it's just clogged?
Old Dec 6, 2015 | 08:56 AM
nateairman's Avatar
nateairman
Run the engine with the valve cover off. Each injector should spit oil the bad ones do something else.
Old Dec 6, 2015 | 09:24 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
What Nathan said. Ps. Nathan's not far from you either lol. If you see one not spitting you can try to move the injector around and see if the problem follows it.
Old Dec 6, 2015 | 09:37 AM
oldbird1965's Avatar
oldbird1965
I know another guy on here that switched some wires around by accident and after finding the problem and correcting it didn't have any lasting effects.
Old Dec 7, 2015 | 05:18 PM
Alec Blanchard
Well I've put about 1000kms on it so I don't think it's gonna fix itself. I suppose next time I'm under the hood of my 7.3 I could run it without the valve cover. Now I'm working on my fix.0 lol. Cracked egr cooler.
Old Dec 14, 2015 | 01:53 PM
Alec Blanchard
Here's the thing. Just got in it to warm it up this morning and put my high idle on, and it runs on all 8. Idle to 1000 runs rough. What else could it be?
Old Dec 14, 2015 | 02:43 PM
MOOSE_MACHINE
mine idles rough at 1000. Smooth as can be at 1100
Old Dec 14, 2015 | 10:49 PM
Alec Blanchard
My brother has the same truck in ext cab zf5, and my dad in cc auto. Both are smooth from off idle to redline. All trucks are stock, besides downpipe.
Old Jan 14, 2016 | 02:19 PM
Alec Blanchard
Old Jan 14, 2016 | 02:38 PM
stainlessstroker95's Avatar
stainlessstroker95
Is there oil in your fuel filter?
Old Jan 14, 2016 | 02:45 PM
Alec Blanchard
Haha. Not likely. It's brand new. Rpm and "roughness" are very consistent. All I need to know is if and how I can fix it, or if I need to go buy a new engine.
Old Feb 21, 2016 | 12:52 AM
Alec Blanchard
Well gents, I figured it out. I was looking in the wrong spot. The factory harness was rubbing thu on the driver side front injector harness. taped er up and now she's runnin on all 8.
Old Feb 21, 2016 | 08:46 AM
oldbird1965
Better then a new engine
Old Feb 21, 2016 | 11:53 AM
z31freakify's Avatar
z31freakify
Happy ending always good.
FiznUKa
15
Apr 9, 2021 07:39 AM
Visseroth
31
Jul 27, 2011 12:54 AM
PhilnMarilyn
Aug 18, 2010 07:14 PM
97 HD
Oct 23, 2007 09:22 PM
4dtough
31
Oct 18, 2007 06:14 PM
