Blowing smoke suddenly
Old Dec 1, 2015 | 05:16 PM
burnthelight88's Avatar
burnthelight88
So I've had the truck almost a year and never had any smoke coming from the tailpipe during starts or otherwise. I recently parked it for about a month while I was slowing replacing vac lines back to the factory diagram. During this time I also did a 2150 carb rebuild and adjusted everything on there. Also threw a new EGR and gaskets on.
I suddenly have what I'd call a medium amount of grayish smoke pouring from the tailpipe, doesn't seem to change/stop after warm-up. Does it have something to do with the new EGR or something else I did, or is it just coincidence?
Also noticed that the temp gauge spiked to almost the highest end this evening after about a 10 minute drive, haven't had time to independently test the temp and the engine didn't seem that hot, but thought I'd mention it in the event that someone thinks they're related. I don't think it could be related because the smoke was about the same level before the truck even warmed up.
Old Dec 1, 2015 | 05:48 PM
jim collins's Avatar
jim collins
Is the radiator staying full ? That sounds like water in the cylinder or cylinders . Could have a gasket leak in to the engine. If it's antifreeze burning it will have a sweet sorta smell to it. That's the way it was when i blew a head gasket on a car once.
Old Dec 1, 2015 | 06:19 PM
burnthelight88
The radiator isn't staying full but that's because it's got a small leak. I also would've looked for the missing coolant but unfortunately I can't go by that right now and I've got no time for the rad replacement job until spring.
Old Dec 1, 2015 | 06:22 PM
Thinlizzy13's Avatar
Thinlizzy13
Like Jim said it does kinda sound like burning coolant. My '82 F150 had a blown head gasket, although the smoke was more white than gray.
For what it's worth I took all the emissions stuff off of my '82 and the exhaust is always grayish now. Maybe something isn't hooked up correctly/no longer functioning?
mountain dewd's Avatar
mountain dewd
Replacing a radiator is, at the most, a half hour job. If it is the problem, just go for it.
Old Dec 1, 2015 | 06:23 PM
Tedster9's Avatar
Tedster9
Blue smoke - oil burning
Black smoke - excess fuel burning
White smoke - antifreeze burning
Old Dec 1, 2015 | 07:42 PM
burnthelight88
Well the radiator is one of the problems but the leak is small and I just keep it topped off. I know the radiator itself is a short job but in the spring my plan was to flush all the coolant and replace everything along the way, hoses, thermostat, core etc.
I figured the head gasket could be the problem but was hoping not. Last oil change didn't appear to be anything except really old oil. Guess it's just coincidence that it started after I replaced the other stuff.
If the head gasket is going, could that alone raise my operating temp? Like as long as I keep the radiator topped off it shouldn't be overheating based on that right?
Old Dec 2, 2015 | 12:45 PM
Filthy Beast's Avatar
Filthy Beast
Since you're not burning oil (blue smoke), I would "sorta" eliminate the head gasket...unless the new oil manged to dislodge a piece of the gasket near the water jacket. (Unlikely). If the head gasket is old and brittle, it could be going..... A warped head would cause gray smoke.....pull a plug or two and see what they tell you.
Do you have dual exhaust? Smoke coming from one side only?
Check your thermostat for functionality.....replace (if needed) with a 190*
How's the water pump? You could pull the T-stat, uncork the radiator, fire her up and watch for flow....also keep an eye out for bubbles in the coolant.... = cracked/warped head, head gasket going south, etc.
Old Dec 2, 2015 | 05:21 PM
burnthelight88
Nope, still the factory single exhaust, and man do I need to replace the gaskets on that as well.
Plugs are brand new, so I may have to put some miles on before they really tell me much. I know what lean/rich looks like on a plug, but what would I be looking for in this case?
Winter is coming and I won't be putting many miles on the truck except in very bad weather, spring will be the time I pull the thermostat, water pump, radiator, etc.
Old Dec 2, 2015 | 09:27 PM
Tedster9's Avatar
Tedster9
Plugs will show right away. For lean/rich carb adjusting it's important to avoid idling and low speeds, loading the plugs up. For your purposes just a couple miles is plenty. The porcelain will have a green tinge or heavy white deposits iirc.
Old Dec 2, 2015 | 09:39 PM
ultraranger's Avatar
ultraranger
I didn't see it mentioned what transmission you have but, IF it's an automatic (C-4 or C-6) the vacuum modulator at the transmission could have a hole in the diaphragm.
This will suck fluid out of the transmission and into the combustion chambers of the engine. It will come out the tail pipe as a white or light gray looking smoke.
Old Dec 3, 2015 | 09:17 AM
Filthy Beast
Agree with ultraranger and Tedster9.
The plugs will be pearly white, brandy new and clean looking if she's burning coolant...you don't need many miles for it to show.
Good luck when you tear into her.
Old Dec 3, 2015 | 01:41 PM
burnthelight88
Thanks for providing the color, wasn't aware of that. I'll pull one from each side and see what they look like.
T-18 4spd so no go for that.
Old Dec 3, 2015 | 03:28 PM
Tedster9's Avatar
Tedster9
It may just be leaking into one cylinder? I'd want to check all of them.
Old Dec 4, 2015 | 08:48 PM
Ozzie H.'s Avatar
Ozzie H.
A compression test should resolve the gasket question.
92F150Stpsd
15
Mar 7, 2011 04:40 PM
myboysrmyheart
Oct 30, 2007 04:58 PM
harley51185
1983 - 2012 Ranger & B-Series
Aug 5, 2005 05:27 PM
Harvs86
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 19, 2005 09:46 PM
1985ColumbusF150
Oct 4, 2004 12:09 PM
