White smoke during startup
Old Apr 17, 2005 | 12:36 PM
Harvs86's Avatar
Harvs86
I have only owned my truck for a few months but every so often I get this problem. I startup the truck and get big clouds of white smoke. It only comes out ofr maybe 2-3 min then goes away. Another thing is it does not happen everytime I start it only sometimes. The truck is an 86 2.9L. Thanks in advance.
Old Apr 17, 2005 | 02:20 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Assuming the vapor cloud is not due to cold weather, it's probably a head gasket or cracked head. The 2.9L is an engine that cannot tolerate being overheated; just one time usually results in damage. I'd check your coolant level and monitor it for coolant loss without leakage. I'd also take a look at the dipstick; brown/white milkshake apperance all indicate coolant in the oil.
Old Apr 17, 2005 | 03:01 PM
Harvs86's Avatar
Harvs86
Thanks for the quick reply Cowboy. I literally joined this site like 3 hours ago and I have already seen about 10 recent posts about the cracked heads. I wish it wasn't true but it is most likely the problem. I can remember a couple months ago on the highway and I saw the temp gauge go higher than normal. It probably happened right then. About the vapor thing, Its not possible considering it occurs in 80 degree weather down here in south florida. Thanks again and I guess I am going to have to tear her apart and check for the crack.
Old Apr 19, 2005 | 09:46 PM
dyrbr_d's Avatar
dyrbr_d
White smoke could be head gasket or cracked cylinder head, but blue smoke on startup is normally a sign of bad valve stem seals.
Hotrodon
Nov 22, 2011 10:43 PM
MasterTrim
Jun 28, 2011 03:34 PM
61 uni
May 18, 2007 02:47 PM
beej1024
Feb 24, 2006 05:00 PM
Fordman
Jun 30, 1999 12:31 AM
