46' 2 ton Steering Question
Old Dec 13, 2015 | 07:41 PM
  #31
Joe777's Avatar
Joe777
Success!!!
I was thinking of flushing my steering box out with some diesel then draining it thru the end plate. If I just loosen the 4 bolts enough to let the diesel drain, do I have to worry about the shims coming out? I've never messed with a steering box and don't want to goober mine up.
Old Dec 14, 2015 | 05:44 AM
  #32
Craig46's Avatar
Craig46
Originally Posted by Joe777
Success!!!
The shims on mine would not come out without removing all 4 bolts. I think there is a picture of them in the above photos. Even with the 4 bolts and plate removed the shims were stuck in place.
Also the lower bearing seal of mine could only be removed by lightly hitting the steering wheel gear shaft. This was done after the whole assembly was removed.
I am saying this, just to reinforce the idea that the flush of the steering box that you suggest may not work.
Hopefully some of the more seasoned folks can add some advice.
Old Dec 14, 2015 | 06:35 AM
  #33
Joe777's Avatar
Joe777
Thanks for the info. I'll have to come up with plan B.
Old Dec 14, 2015 | 09:07 PM
  #34
38 coupe's Avatar
38 coupe
On an off topic steering box (VW Beetle) I was able to use an oil squirt can to flush out the guts. I took one of the end plate bolts loose which opened a passage into the oil filled cavity then pumped oil in through the fill plug hole. I don't know if a similar procedure would work for you. If it would it is a lot easier than removing and re-assembling the bearing retaining plate.
Old Dec 15, 2015 | 06:32 AM
  #35
Craig46's Avatar
Craig46
Joe,
An option could be removing the bottom plate, which may allow the cleaning fluid to pass around the worm gear and the bearings? Look at my pictures above and you can see what I am talking about.
Also, I would remove the side plate that holds the adjustment screw for the sector shaft. That would give you plenty of room to see what is going on inside of your steering box as you clean.
Best of luck!
Craig
Old Dec 15, 2015 | 05:31 PM
  #36
Craig46's Avatar
Craig46
Originally Posted by tacomacream
Could you please tell me the specific name of the manual in the above picture.
Thanks,
Craig
Old Dec 16, 2015 | 10:06 AM
  #37
tacomacream's Avatar
tacomacream
I found this on Google. Not a very good pic. Also check out this:http://www.ebay.com/itm/1945-FORD-TR...lVAKE-&vxp=mtr
Old Dec 16, 2015 | 04:32 PM
  #38
Craig46's Avatar
Craig46
Thanks,
That is exactly what I need.
Old Apr 10, 2016 | 02:24 PM
  #39
bernette's Avatar
bernette
does chucks trucks have a internet adress,or phone number! i got the wrong bushings for my sector shaft,and the wrong seal. not sure if joe can furnish me the right one,he specializes in 1/2 tons!
Old Apr 10, 2016 | 02:40 PM
  #40
Craig46's Avatar
Craig46
Chucks email, chuck4850@outlook.com, also his web site is http://www.chuckstrucksllc.com
He should be able to help you out.
Good luck!
Old Apr 10, 2016 | 03:30 PM
  #41
bernette's Avatar
bernette
thanks alot !
Old Apr 15, 2016 | 07:06 PM
  #42
white 66's Avatar
white 66
Steering end play and truck
Originally Posted by Craig46
I could not be happier, there is very little play. Considering her age, pretty much zero play.
Tracks straight and true down the road.
My teenage daughter wants to drive it to school, just about ready! Wish me luck.
Nice truck, thanks for the photos of the rebuild. I am lucky my box and steering are tight.
Rachel Moody
15
Jan 16, 2017 11:51 AM
Fordsdad
Nov 21, 2013 06:52 AM
ltstewart125
Oct 15, 2011 01:30 AM
Heavy One Fifty
Aug 2, 2010 04:40 PM
BIGMT
Feb 11, 2009 03:08 PM
