engine computer problems?
Old Nov 29, 2015 | 12:32 PM
Ian Bonk's Avatar
Ian Bonk
hey guys im new here I needed help on figuring out why my truck is running only on 4 cylinders.... its a 95 f150 I rebuilt my entire engine with my dad, knowing that he used to be a mechanic i decided to rebuild it. (more of a learning experience) all internals parts are fine. Up with torque measurements ect. i bought a new distributor, wires, spark plugs, but numbers 5,7,3,4 are not firing. we've tried everything with the distributor plugs and wires. there is fuel getting to each cylinder because iv taken the plugs out and have seen and smelled gas on them. the only thing we could think of is something electronically/ electrically. so we plugged in the OBD1 tester and alot of codes came up. mostly to do with the electronics. one of which was #15 eca failure. there was #87 and also #81. i went to buy a new computer because of what it said, still no change in firing order. so my question is, does anyone have a clue on what it could be or have any of you has a similar problem, remember its a new engine.
Old Nov 29, 2015 | 01:33 PM
Conanski's Avatar
Conanski
What engine?
Sound like you may have a pinched wire somewhere it's easy to do. Did you change any wiring on the motor with this rebuild?
Old Nov 29, 2015 | 03:09 PM
Ian Bonk's Avatar
Ian Bonk
It's a 302, and maybe... I'll have to look because we've been trying now for days to figure this out, and no luck
Old Nov 29, 2015 | 04:31 PM
rla2005's Avatar
rla2005
You should be getting three digit codes, not two.
The computer fires the plugs based on the stator trigger. There is a tooth that is narrower than the others. This signature pulse tells the computer where cylinder #1 is. Weird things can happen when the distributor is not stabbed correctly. This usually manifests itself with driveability issues, not missing spark. Worth a shot to verify.....
Old Nov 29, 2015 | 05:04 PM
Ian Bonk's Avatar
Ian Bonk
Alright thank you! I'll give it a shot
Old Nov 29, 2015 | 08:30 PM
Ian Bonk's Avatar
Ian Bonk
Also though, I forgot to mention me and my dad used two different distributors, and it both acted the same
Old Nov 30, 2015 | 09:06 AM
subford's Avatar
subford
Sounds like the VSS wave train to the PCM Computer is bad and the PCM Computer thinks the truck is going to fast and is trying to slow it down.
I would guess maybe you have a bad PSOM.
Old Nov 30, 2015 | 09:59 AM
rla2005's Avatar
rla2005
Did you verify the stator is lined up properly on both? It does matter on a sequential fuel injection system. Again, It may be semantics here but it will eliminate issues once you figure out the root cause for this one.
As previously stated also verify all the connectors are plugged in and there are no bent pins.
Old Nov 30, 2015 | 11:29 AM
Nothing Special's Avatar
Nothing Special
Originally Posted by rla2005
You should be getting three digit codes, not two.....
Are you sure of that? I would think a '95 would be EEC-IV with 2-digit codes.
Old Nov 30, 2015 | 11:39 AM
timbersteel's Avatar
timbersteel
'95 would be 3-digit codes.
What we need to find out is what PCM is in there, and what was it replaced with, IF in fact he is getting 2-digit codes.
What code reader are you using?
Old Nov 30, 2015 | 05:05 PM
rla2005's Avatar
rla2005
Ford started the transition to 3 digit codes around 1991. Subford has stated some went to three digit as soon as 1989.
Old Dec 1, 2015 | 07:48 PM
Ian Bonk's Avatar
Ian Bonk
I bought a new computer the pcm one because that's what we thought it was too, but there was no change in the firing order
Old Dec 1, 2015 | 08:46 PM
rla2005's Avatar
rla2005
Disconnect the SPOUT then check your spark. Even better disconnect the computer completely. This will make the spark control revert to basic mode. The ICM will trigger off the raw PIP signal.
Old Dec 1, 2015 | 09:59 PM
Eddiec1564's Avatar
Eddiec1564
Recheck the ignition order of that 302, it could be the H.O.302 ignition order instead of the standard 302. I read a thread few days ago about that.
Just removing the SPOUT will allow no ECU timing functions and engine will run on base timing. If you remove the ECU then the injectors will not be working and engine will not run unless you use starting juice to give fuel to engine.
Old Dec 2, 2015 | 05:50 AM
rla2005's Avatar
rla2005
I was pointing the OP to look for spark on all cylinders. I was not concerned about the engine running.
Wrong firing order would not cause a no spark on certain cylinders condition.
speedaemonc4
Nov 30, 2017 01:45 PM
StrangerRanger89
1983 - 2012 Ranger & B-Series
Feb 9, 2011 12:22 AM
Rob1973
Sep 19, 2007 08:42 AM
pfd843
1997 - 2003 F150
Jul 31, 2006 08:05 PM
Cerulean
1978 - 1996 Big Bronco
Mar 26, 2006 02:01 AM
