Had a wandering steering problem and read many threads on the subject and started moving towards adjusting the steering box. As I got into it, I found a completely different problem that nobody has touched on yet! I pulled the steering shaft out of the vehicle after detecting the slop somewhere before the steering box. To my surprise, I found almost all of the splines in the lower universal joint gone! Had I ignored this problem, this definitely would have resulted in a complete loss of steering. I've attached some photos of what I discovered. I had to pull the inner wheel well to see the problem. Needless to say, a complete new steering shaft is in order. Hope this helps!!
