steering box
Old Nov 26, 2015 | 12:07 AM
Hogtrapper's Avatar
Hogtrapper
steering box
Happy Thanksgiving gentlemen, I hope you and your family have a blessed day. I am planning on working on my 1985 F250 4X4 351W steering box. It has dana 44s. The problem is slack in the steering, it's not bad but it is road walking a little bit. There is a small amount of slack in the linkages so they will be replaced, but the ball joints were replaced about 4 months ago. The steering wheel has approximately a 1/4 turn (or a little less) slack in it. Since I will have the truck down replacing the linkages and the steering box seems to have a little slack in it and leaks fluid I am thinking of rebuilding it also at the same time.
My question is have any of you gentlemen done this before? Do you have any advise for me? I have never done this before and would appreciate any and all input. Would I be better off just buying a new steering box? Is this a very difficult job to undertake? Thank you in advance for your input.
Old Nov 26, 2015 | 01:16 AM
FordFETruck's Avatar
FordFETruck
1/4 turn of slack? are you nuts to drive it like that? everything under there is very straight forward, add a steering box to the list if it really has that much slack. Have it aligned after all the parts are replaced.
As far as the steering box, rebuilding it yourself or buying a parts store reman is a waste of time and money. These boxes have problems that are only corrected by custom re-builders like Redhead. I have one of their boxes and it drives great.
Old Nov 26, 2015 | 10:11 AM
Hogtrapper's Avatar
Hogtrapper
Thank you for your input FordFETruck I appreciate it. LOL 1/4 turn slack ain't nothing, try driving one with a full turn of slack, makes for an interesting ride LOL. Do you have a link to Redhead? I apologize for my ignorance but I'm afraid if I google Redhead it'll take a long time to sift through all the results, any help would be greatly appreciated. Again thank you for taking time to advise me on this problem.
Old Nov 26, 2015 | 10:22 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Pull the plastic sleeve back and check the condition of the rag joint while you're looking at the steering shaft.
Old Nov 26, 2015 | 12:08 PM
FordFETruck
LOL, here you go.
Red-Head Steering Gears - Custom Rebuilt Steering Gear Boxes in USA
Old Nov 26, 2015 | 01:15 PM
ctubutis's Avatar
ctubutis
...I'm afraid if I google Redhead it'll take a long time to sift through all the results....
Heh... I can imagine there being significantly different results specific to both boys and girls....
Old Nov 26, 2015 | 06:30 PM
Hogtrapper's Avatar
Hogtrapper
Thank you sir....I've got to show my ignorance here but what is the rag joint please?
Originally Posted by FordFETruck
Thank you sir I will definitely check them out.
LMBO you are exactly right LOL. There were some "results" that would make a sailor blush. I knew googling redhead would produce some "interesting" results but some of the results were.....well more than "interesting". LOL
Old Nov 26, 2015 | 07:23 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The rag joint is a flex coupling in the steering shaft made from a disc of cloth reinforced rubber (like a chunk of tire sidewall)
First google photo search brings this..
http://mustangforums.com/forum/classic-mustangs-tech/636094-rag-joint-inspecting.html
Old Nov 26, 2015 | 08:17 PM
FordFETruck
It would be this.
Old Nov 26, 2015 | 08:59 PM
Hogtrapper's Avatar
Hogtrapper
Ahhhhh ok I got it now. I have seen these joints many times but didn't know the name of it. Many many thanks gentlemen I will definitely check that tomorrow. Honestly checking that never came to mind, I really appreciate your input.
I did check out Redhead and I like the looks of their products. After I do some more investigating on my truck I am sure I will contact them about a replacement steering box. Again thank you gentlemen for your input and advice.
Old Nov 26, 2015 | 09:56 PM
Gary Lewis's Avatar
Gary Lewis
Redhead actually improves the Ford boxes. Originally the front of the shaft rode in a hole in the cast iron casting - meaning there was no bearing. Redhead bores the casting out and installs a true bearing there. But the other rebuilders just put new parts in the box, so if the box itself is worn it'll still have slop.
FTE frequently has group buys going on with Redhead, so when you call check to see if one is in progress.
Old Nov 27, 2015 | 10:32 AM
Hogtrapper's Avatar
Hogtrapper
Thank you Gary, I appreciate the intell. I will definitely ask them about this.
DanielT28
83
Jul 12, 2015 10:56 AM
SNIPER168308
May 14, 2009 05:46 PM
78longbed
Jul 14, 2008 04:41 PM
agryphon
1983 - 2012 Ranger & B-Series
Sep 28, 2006 10:11 PM
ford351c
May 19, 2003 10:14 PM
