7.3 Brothers:
I started the rig this morning, after idling for say 20 minutes, the engine automatically went from it's idling purr of (700 RPM's) to a higher idle
(1000 RPM's) automatically. So I tapped the accelerator gently to bring it back down off of the higher idling. So far so good, then; After 10 minutes, engine automatically started creeping back up to 1000 RPM's. Is this a normal operating function of the motor in colder temps. or is there something else going on that I should have looked at? It has been under 20 degrees for the past 5 days. No check engine light on or anything. Thx
Actually, more reasons. Warm up when cold, and long low idles either raise emissions, wash down the cylinders, or both - I remember reading something on those and the "both" answer seems to fit how a diesel works.
I think your right. That and a wear pattern on the bearings. I heard there is an "ambulance" tune or something to prevent it. I know a buddy had gotten something like that on his 00 for his work truck. It idles for hours/ days at the jobsites.
