Heater hose part # and installation help
#61
#62
Thanks !
#63
The ball valves shut off hot coolant flow through the heater cores so the air conditioning blows colder. Excursions have two heater cores. The reason I installed two shutoffs was to COMPLETELY isolate the heater core loop versus just one shutoff on the inlet side. Open them in the cooler months and your heater can use the heater cores the way they were intended. The factory vacuum valve is supposed to shut coolant flow off with vacuum when the air conditioner is turned on Max Cool for the same purpose but doesn’t completely shut the flow off.
#64
You probably won’t find a fitting better or cheaper than this stainless one, that’s why so many guys bought and installed them. Don’t skimp on it or you’ll be having to redo it again. I searched for days and found this one. There’s a reason it’s made for maple syrup pricessing, it’s hard to find a fitting this shape, material and configuration.
Questions:
1. Where exactly is your 2nd ball valve located? Degas bottle area?
2. What type of valve did use (barbed / threaded etc) and where did you purchase it from?
I'm in Ontario so I need to part out products as best I can locally.
Ford Canada wanted $482 (shipped from Miami) for the entire hose assembly from heater valve to firewall - NOT happening!
Thanks!
#65
With your reply I was able to temporarily insert a pvc 3/4 plug into the line pre-heater valve - to stop the truck from leaking all over the place. I actually called the Maple syrup gurus earlier today and ironically the one store was out of the product! They've contacted their other store to see if they have more in stock.
Questions:
Thanks!
Questions:
Thanks!
Talk to Ed or Scott and let them know that you come from FTE.
FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
#66
Questions:
Thanks!
Questions:
Thanks!
#67
Appreciate the Feedback SmackDaddy. Your picture of the Passenger side of the Excursion is great - do you have a picture posted of your ball valve setup on the Degas side of things? If not , could you?
I'm going to be ordering both Wye adapters from the Syrup folks and save some headaches down the road. (3/4 x 3/4 x 3/4 - Heater & 1 x 1 x 3/4 - Degas). I'll be also looking for that 3/4 Apollo barbed valve you posted as no stores around here seem to carry a similar product.
Thanks !
Thanks !
#68
Thanks !
Thanks !
#70
yes, i've just found those valves on Amazon thank you.
If you have the opportunity for a real time pic it would be appreciated as I not sure i'm seeing what you're trying to point out to me (my eyes / pic won't zoom in etc).
Nonetheless I'm further ahead than i was before - both wye adapters are ordered and valves.
#71
DavidE
02-25-2012 05:42 PM
