Improve reverse lights?
Old Jan 5, 2016 | 04:04 PM
  #61
danorth's Avatar
danorth
Trailering
Wiring the switch in... Using this picture of a different part than listed above:
Amazon.com : Bandc LED Marine Boat Jeep 4 Pin Spdt On-off-on Rocker Switch with 2 Lights Waterproof : Sports & Outdoors Amazon.com : Bandc LED Marine Boat Jeep 4 Pin Spdt On-off-on Rocker Switch with 2 Lights Waterproof : Sports & Outdoors
goes like this:
Where 7 goes to the ground in the 7 pin tow outlet, 1 would be the reverse from the tow outlet, 3 would be the constant 12V, and 2 would be the + wire to the lights. That way the switch connects either 1 and 2, or 3 and 2, or I can set it in the middle for off. This way I am using the built in reverse switch that sends current to the 7 pin tow outlet. Does that sound correct? Then the lights themselves are grounded to the chassis.
Old Jan 8, 2016 | 01:32 PM
  #62
jpcjguy's Avatar
jpcjguy
Originally Posted by danorth
Ok, I bought the LED replacement bulbs and one didn't work, so I sent them both back. Here is my next plan:
Amazon.com: Nilight 36w LED Flood Work Light Off Road LED Light Bar Super Bright for Jeep Cabin/boat/SUV/truck/car/ATVs, 2 Piece: Automotive
Amazon.com : Bandc 7 Pins 2 LED Light On-off-on Marine Boat Rocker Switch Dpdt Waterproof 12v 24v : Sports & Outdoors
Amazon.com: Pollak 12-706 Plastic Blade Style 7-Way Plug: Automotive
I don't tow often enough to worry about using the outlet. So, I plan to wire up this blank 7 blade plug to use the power from the reverse and constant, and use the ground. These wires will go to the 3 way switch so I can turn this light system off, or on, or when only in reverse. There are already 2 holes under in the towing frame (proper term?) for mounting the lights, and a spot to place the switch. Anyone with more experience with tinkering see a problem with my idea and parts listed?
Alright - I just ordered the same lights and switch as danorth. I am NOT going to wire it up to the towing outlet - as I do tow.
Is this a correct diagram I found?
So what is the best way to wire this up? Do I need diodes? What size? Recommended wire size? Not great at the electrical stuff.
Thanks!
Old Jan 14, 2016 | 09:31 AM
  #63
jpcjguy's Avatar
jpcjguy
Originally Posted by LivingLarge
My LEDs look like the Cree but different brand (you see the yellow in the lense) They help but nothing is better than dedicated reverse spots.
Attachment 128928
LivingLarge - can you take a pic of how you mounted the lights?
Thanks!
Old Jan 18, 2016 | 03:39 PM
  #64
USCG_PA's Avatar
USCG_PA
I saw these at the local auto parts store, might be an option for those looking for cheap and easy backup assist lights...
https://www.etrailer.com/Vehicle-Lig...ve/PL-807.html
Old Jan 19, 2016 | 06:47 AM
  #65
jpcjguy's Avatar
jpcjguy
Got my lights installed! Kind of a PITA but happy with the result
Old Jan 19, 2016 | 08:05 AM
  #66
LivingLarge's Avatar
LivingLarge
Thanks!
Fabricator just welded a custom bracket to my tow hitch, I'll try to snap a pic today and post.
icentropy
Jan 12, 2014 08:59 PM
jwill8957
2009 - 2014 F150
Oct 20, 2011 04:46 PM
mtondreo
Dec 23, 2009 06:26 AM
rodsterman
Feb 10, 2004 11:05 PM
