Transmission Cooler Line Issue
Old Nov 23, 2015 | 09:33 PM
Yahiko's Avatar
Yahiko
FTE Remembers
Originally Posted by mwoolard1912
Finally got them. Thanks for the advice. I fixed a board for the passenger side and then tapped on it a little before I tried it. Popped right out. Driver side was a different story, tried several times using the same method as the passenger side with no luck. Finally I had a moment of genius. I used to do a lot of construction work and I had forgotten I had a tubing flair kit. I got the clamp you put on the tube to hold it to flair it out. It had a 1/2" hole in it. I put it on the line behind the release tool and pushed it up against it. this helped hold the tool still while I pulled and / or pried on the line to get it loose. It also doubled as a handgrip to pull on it. I wiggled it a couple times and out it came.
If you happened to have one of these tools I would suggest it to anyone trying to get these things out. I think it would have saved me tons of time had I thought about it earlier.
Now it's time for a beer . Thanks everyone!
I like that idea.
My Rotor-flair tool would not work for that job. BUT maybe one of the dye sets might if
one were to rig it up right.
Sean
6.0L Tech Folder
OJs DNA
Jul 10, 2016 05:38 PM
mattf76
Modular V10 (6.8l)
May 4, 2016 10:48 AM
O's Fan Rich
Dec 28, 2009 12:44 PM
namdorf
May 28, 2008 10:16 PM
broncoholic
May 9, 2008 08:26 AM
