New Fuel Line Question
Old Nov 21, 2015 | 09:22 PM
AK FORD GUY's Avatar
AK FORD GUY
I plan on running new fuel line on my truck when I get home in a week or so. I know there was a thread about it somewhere, I searched and could not find it.
I believe it was about double annealed stainless steel tubing. it was corrosion resistant and easy to bend / flare. I think this is what I would like to use in 3/8".
http://www.jegs.com/i/JEGS-Performan...arentProductId=
I believe this is the stuff folks were talking about, just want to make sure before pulling the trigger.
Old Nov 22, 2015 | 02:46 PM
AK FORD GUY
This is in stock at the local parts store, I'll probably just go with it.
http://m.autozone.com/brakes-and-tra...&showymme=true
The price is more within my budget as well.
Old Nov 22, 2015 | 07:06 PM
Blue and White's Avatar
Blue and White
That steel line from AZ looks fine. Steel lasted a long time on these trucks and it is easy to work with. SS is much harder to cut and flare. I used the same type of tubing from AZ in 3/16" to re-make a brake line yesterday.
Hopefully you are more artistic than I am with tubing... I can get from point A to point B OK but buy pre-bent from inline tube if it needs to be pretty.
Old Nov 22, 2015 | 07:18 PM
AK FORD GUY
Thank you. I am no artist either... Point A to Point B and functional. I want it to look good, but show quality is not in my budget.
I am going to install a return style fuel system and depending on hoe the first line goes, the original line may become the return line. I want to run two new lines, but we'll see how the first one goes.
Old Nov 22, 2015 | 08:47 PM
ZarK-eh's Avatar
ZarK-eh
What about using nylon fuel lines?
The kind used on more modern vehicles. They last forever like those poly fuel tanks. But are a bit of a pain to setup but boiling the ends in water will ease assembly.
Old Nov 22, 2015 | 08:54 PM
Tedster9's Avatar
Tedster9
NAPA (and others) sell Nicopp "brake line" that works perfect. It has the fittings on the ends that fit carbs and fuel pumps perfect. Kind of a greenish color.
Just make sure the fitting is where you want it before bending. Ask me how I know. The one I have on here now is way too long, they were out of what I needed. It works, just looks silly. I'll get around to replacing it eventually.
Old Nov 22, 2015 | 10:57 PM
AK FORD GUY
Thanks Tedster, I'll check it out when I get back into town. I'm either going with the NiCopp or the Poly Armour Coated steel. Depends on the price once I get my hands on it.
Old Nov 24, 2015 | 12:06 AM
burnthelight88's Avatar
burnthelight88
I just replaced my full length of line with aluminum 3/8" line from speedwaymotors.com Very easy to bend and work with, price is right. I did the full line front to rear in under an hour.
farmnaggie
Sep 23, 2014 08:36 PM
bio short bus
Nov 20, 2011 09:36 PM
kepi13
May 3, 2009 06:50 PM
TheSojourner
Aug 10, 2008 03:24 PM
ErrorS
Jun 20, 2007 09:09 PM
