1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
OD Light "Acting Up" but Not Blinking, No Codes
Old 11-11-2016, 09:51 AM
Tmurphy38's Avatar
Tmurphy38
Tmurphy38 is offline
Hello all,
2002 Expedition, EB 5.4 Triton, 2WD, 4R100 (overhauled about 25K miles back)
After starting the vehicle, The "OD Off" light on the stalk illuminates as soon as I shift into DRIVE, (or any other position), and stays on (not blinking). However, OD is NOT disabled at this point, which is ostensibly correct since the OD button has not been pressed. Pressing the button will disable the OD as expected, and subsequent presses behave normally, switching OD on and off. The light remains on constantly, until I shift back to PARK, where it turns off.
In PARK, the OD light turns on and off with the button as normal.
The light is not blinking and there are no codes.
Possibly a short in the stalk head or steering column?
Thanks in advance for any insights!
Tom M
Old 11-11-2016, 07:46 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The wiring harness is chafed where it exits the shift lever. Pull the column shrouds and repair, it will be obvious.
There are three wires in that little harness, the exact symptom depends on which wire shorts to ground first.
Old 11-13-2016, 08:35 PM
Tmurphy38's Avatar
Tmurphy38
Thanks! I'll check it out!
Tom
roboteacher
07-01-2006 04:20 PM
Torsen Rick
03-02-2005 10:52 PM
blairw
1997 - 2003 F150
02-08-2005 04:45 AM
tommyl
1999 to 2016 Super Duty
08-20-2004 03:19 PM
charlie calcote
06-23-2003 11:09 AM
Quick Reply: OD Light "Acting Up" but Not Blinking, No Codes
