Rims Help!
Old Nov 11, 2015 | 09:43 AM
Smittty's Avatar
Smittty
I actually found another set that has the pattern I'm looking for. Thanks. But I'll snag these ones to becuse I do have the all the resources and machinery to do it when I'm not working on aircraft. Thank you.
Old Nov 11, 2015 | 06:42 PM
Macrobb's Avatar
Macrobb
Originally Posted by IDIoit
all it takes is a sign plate and a mill.
pretty easy in the eyes of a machinist.
but youll be making your own lugnuts also.
a machinist makes approximately 150/hr.
so thats an hour to set up the mill
and roughly an hour for each rim.
then swap over to the lathe for the lugnuts to make 32 lugnuts?
forget all that, ill buy the correct ones.
Why make lugnuts? Just countersink the new holes(something that could actually be done freehand/with a drill press) and use your existing lug nuts.
As for drilling out new holes, seems like I could do it just fine without the sine(sign?) plate... Just draw out x/y cordinates for all 8 new holes, dial in the center hole, and drill each. Clamping the wheel to the table with a couple of studs through a couple of the existing holes would be the easiest thing to do.
Old Nov 12, 2015 | 12:36 AM
IDIoit's Avatar
IDIoit
sine, yes sine...(insert excuse here) a rotary sine plate at that.
i would want to bore out the entire hole and not use the counter sink method.
my point was, IMO.. ill just buy correct rims.
as far as machining methods, theres many ways to cook a cat..
or was that skin a cat?
Old Nov 12, 2015 | 09:50 PM
Macrobb's Avatar
Macrobb
Oh, you mean for the middle hole?
Where's the fun in that? Why spend $50 on good rims when you can spend $500 hacking $5 rims? :P
Both?
bignewf
Apr 15, 2016 08:46 PM
Ron/RPMS
Jul 30, 2011 05:06 PM
Ravenwood Ranch
General Diesel Discussion
Jul 9, 2009 09:03 AM
OKMIC1
May 1, 2008 05:39 PM
