Sand blaster attachment for pressure washer
I got an attachment for my pressure washer that makes it into a sand blaster. My plan is to use this to remove the paint/surface rust for paint and body work prep on my entire truck. I figure this will save me hours of sanding.
Has anyone ever used this method before?
It shouldn't warp the metal at all because the water will keep it cool but what would I need to do to keep it from rusting after?
What media works best?
All advise is appreciated
Thanks for the offer, I'm sure I have something that will work as a guinea pig. But yes, I'll test it on something I have sitting around first so I don't end up screwing up my body panels. That way I can see how well it works, if/how fast rust will start and what works best to prevent it etc.
There are commercial services that advertise these - they say the water cools the panels, preventing warping, and keeps the dust down since the dust and abrasive are trapped in the water. Costs about $6000 to buy the commercial system and when I called one of the folks they referred, he quoted me $1200 to strip the paint off my truck. Their videos are impressive, but it doesn't seem like they are taking the market by storm.
I wouldn't use that on any body panel I care about. With air & sandblasting, you are using maybe 150 PSI. With a pressure washer & the attachment, you'll need 2000 to 3500 PSI of water pressure. That is enough pressure to put furrows right in the metal when sand is added. On a frame, you'll be fine. On body panels, I see ruined parts.
I work for an equipment rental company, we carry about 25 pressure washers for rent. We have tried a few different brands of the sand injector, all are very troublesome, hard to get working & keep working. Maybe you'll get lucky & have one that works, but it is not the sort of thing you can rent to most people. In fact we stopped carrying them as it wasn't worth the hassle.
Someone mentioned using soda as the medium in this attachment. You can't do that, the soda dissolves in water.
I already have one, but it's a little bit under the GPM (gallons per minute) rating for the blasting attachment. I'm going to try my pressure washer and see how it works. If I need more GPM I'll rent one or borrow one from my uncle. Not sure when I'll have time to do this since I'm at college right now but I'll post my results when I do.
I found a product made by Eastbay called "after blast" which will prevent the flash rusting so I plan to apply that after I do any blasting.
Scottscott, I appreciate your input. I already have the attachment so I figure I'll try it anyway and see if it's worth using. Like I said earlier, I'll test it on something else before I use it on any of my body panels
HIO said it best once, maybe more than that, but I remember this one time in band camp...
He called it "flash rust". any bare metal left the elements will get a film of rust over it very quickly and just because you can't SEE it, hit it with a fine grit piece of sand paper the next morning. Blow dry (compressed air) and bring er inside.
