Engine Coolant Temp Sensor locations?
Old Nov 3, 2015 | 04:20 PM
Gatordog's Avatar
Gatordog
I was going to order a ECT gauge and was wondering where to mount the sensor. I have already used the port under the T-stat for the coolant filter. The gauge sensor is a 1/8 NPT. Would the block drains be a good location, or is there another location that will work.
I know the coolant filter housing has a port, but I would prefer the sensor be on the motor.
Old Nov 3, 2015 | 06:48 PM
bigb56's Avatar
bigb56
subscribing because I want to move my aftermarket sensor off the coolant filter housing. So far the only solution I have come up with is a tee into the factory sending unit hole. Or just get rid of the factory one.
Old Nov 3, 2015 | 06:54 PM
Gatordog's Avatar
Gatordog
Thanks, so far this is the only thing I have found: 44 MM or 1 3/4 Inch Water Sender Attachment
It looks like it would work, but I would prefer to mount the sensor on the motor. I would like to know what the block drain is so I can have all the parts ready to go. Don't want to spill to much coolant
Old Nov 3, 2015 | 07:04 PM
bigb56's Avatar
bigb56
The block drains are 1/2" pipe thread. Easiest one to access is driver side, IIR pass side is partially blocked by starter.
Old Nov 3, 2015 | 09:05 PM
crop harvester's Avatar
crop harvester
I think the filter head for the coolant filter on Mine had a port for a sender.
Old Nov 4, 2015 | 07:16 AM
Gatordog's Avatar
Gatordog
Yes mine does also, but I would prefer to mount the sensor on the motor not after the T-stat or on the filter housing.
I will mount at the block drain, I was just wondering if there was another port somewhere else. I guess not.
Old Nov 4, 2015 | 08:13 AM
Fat Diesel's Avatar
Fat Diesel
I'm curious why people don't want to use the port on the remote filter? Are you worried that the temp differential between the two will be significant? Next time you pull into your driveway with the truck to temp, take an infrared thermometer and check the filter housing and the water pump. Let us know how far apart they are. I bet not much.
Old Nov 4, 2015 | 09:21 AM
Jdeshler's Avatar
Jdeshler
^Agreed..
I have been wanting to install an after market gauge because my dash gauge seems to run cold but the heater will run the **** ants out of the cab..
Old Nov 4, 2015 | 06:01 PM
Gatordog's Avatar
Gatordog
If you have a sensor after the T-stat, and the T-stat does not open the sensor located at the bypass coolant filter will not read what the actual motor temp is. Also, I think that if at the coolant filter and there is no water flow because of a blockage or no flow you would not get a reading since there is no coolant flow (maybe even air)
Old Nov 5, 2015 | 08:09 AM
Fat Diesel's Avatar
Fat Diesel
All of the coolant filters I've seen on 7.3's bypass the T-stat.
Old Nov 5, 2015 | 08:15 AM
Gatordog's Avatar
Gatordog
That is true, but the location is very high, if you do get a big leak than you have the air problem again which will result in a bad or no reading. I still think the block drain location will be the best location. I might be wrong, but just can't see the disadvantage of this location.
Old Nov 6, 2015 | 11:46 AM
Fat Diesel's Avatar
Fat Diesel
If you're leaking so much coolant that you have air coming out of your water pump, you have much bigger problems than reading the temp!
homertwo
Jan 23, 2019 08:45 AM
savage250
Feb 1, 2012 10:43 AM
duback66
Jun 29, 2011 04:42 PM
BigBlue92
Mar 27, 2011 09:10 AM
musickerns
1997 - 2003 F150
May 20, 2009 05:15 PM
