4 wheel drive
Old Nov 3, 2015 | 08:36 AM
g tinsley's Avatar
g tinsley
4 wheel drive
I have 2005 f350 will not shift on the fly. with a vacumn pump it will hold vacumn at both hubs but will not lock up. the seals should be good .help appreciated.
Old Nov 3, 2015 | 08:53 AM
87crewdually's Avatar
87crewdually
There's 2 parts to the system. The vacuum locking hubs which you are aware and the electronic shift motor side.
Can you hear the motor shifting the transfercase?
Old Nov 3, 2015 | 10:56 AM
WatsonR's Avatar
WatsonR
you can turn the key on without starting the truck. After the fuel pump shuts off, switch to 4 high and listen for the motor.
Old Nov 3, 2015 | 01:17 PM
bobv60's Avatar
bobv60
Mine wasnt working right. Cheeked for vacuum leaks and everything was good but would have a large leak when 4WD was selected (hvac blend doors would move to defrost ). Replaced the hub control valve and works good now.
Old Nov 3, 2015 | 02:15 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Hub control valve, is that the pump on the left side behind the battery?
My 06 didn't work and I just completed both sides, u-joints and seals and now my on the fky works, yea me.
Old Nov 3, 2015 | 02:16 PM
MisterCMK's Avatar
MisterCMK
Like others have said, check the solenoid on the fender. I found mine was cracked.
Old Nov 3, 2015 | 03:42 PM
Rusty Axlerod's Avatar
Rusty Axlerod
is there a quick way to check it with a meter or power? I'm having issues also and have done 0 research.
Old Nov 3, 2015 | 04:25 PM
TeachNlive4ever
here's your research and get back to us. As someone said, turn your A/C on, then swith to 4hi. Does the air then start coming out of the defrost vents?
Old Nov 3, 2015 | 05:14 PM
Rusty Axlerod
I'll start another thread so I don't .
Old Nov 3, 2015 | 06:40 PM
g tinsley's Avatar
g tinsley
4wheel drive
The actual comes out the vents like it should it does not have a vacumn leak
Old Nov 4, 2015 | 03:51 AM
Yahiko's Avatar
Yahiko
Ok I posted the 4WD PDFs in the thread Rusty had before I had seen this one.
You can have a look at the info here >>> https://www.ford-trucks.com/forums/1...l#post15765192
Sean
6.0L Tech Folder
Old Nov 4, 2015 | 07:32 AM
TeachNlive4ever
The hub it's self has a diaphram in it. Who did the bad a$$ write up on these Gambonie? I can't remember his name.
Brian Emory
6.4L Power Stroke Diesel
May 11, 2019 03:13 AM
DJMORETON
Jan 11, 2011 08:36 AM
dogerbrown1
Sep 22, 2010 06:43 PM
bartric
Sep 26, 2009 03:01 PM
bkvanbek
Nov 11, 2007 02:15 PM
