Small roar at low throttle
Old Nov 1, 2015 | 09:01 PM
jed1894's Avatar
jed1894
Ok, still working out some issues:
It may be normal, but I hear (not feel) a slight roar when I'm pressing throttle petal very lightly. Seems to do it as we'll when I'm backing off throttle but it stops when I let off pedal completely. Not there when I get into the pedal. Not the tires because it stops all together when I get off throttle and let it roll. Turbo maybe ? Rear end (wouldn't it do it even when rolling)? No vibrations at all....just a little roar.
Any ideas ?
Thanks
Old Nov 2, 2015 | 06:14 AM
Tugly's Avatar
Tugly
If you have no symptoms of any issues other than a weird sound, my experience would tell me to roll with it. "Stinky has moods". My truck will not only change sounds, but feel different without an army of mechanics or myself understanding why. If it's just a subtle oddity with sound, you might not be able to record it to share on the forum. If this is the case, I would file that under "The nuances I notice as I get to know the truck better".
Old Nov 2, 2015 | 07:10 AM
bigb56's Avatar
bigb56
probably your cooling fan
Old Nov 2, 2015 | 09:56 AM
HKusp's Avatar
HKusp
Tell us much more about your truck. What mods, miles, auto vs. manual, etc.
Old Nov 2, 2015 | 04:24 PM
jed1894's Avatar
jed1894
Sorry
2001 7.3, 188k miles. Crew cab, 4X4, auto, Stock other than Warn hubs
Old Nov 2, 2015 | 07:49 PM
Rikster-7700's Avatar
Rikster-7700
Could it be your rear end? I know mine started with a low roar/howl and got worse pretty quick, and had similar conditions under which it made the noise. Mine has about the same, actually a little less miles on it when it happened. It could also be your carrier bearing.
This is a relatively easy and importantly free diagnosis.
Jack the rear end up, put it on jack stands, CHOCK/BLOCK THE FRONT WHEELS (also may a good idea not to point the truck at anything you would miss if it came off the stands and headed out!)
Check the middle of the truck and around the rear end for any weird noise (do not crawl under the truck or get near any moving parts in the process).
Do NOT forget to brake until the wheels stop before putting it back in park, the pawl makes a hell of a racket if you try to put it in park with the wheels still turning (ask me how I know!)
You can check the magnet on the rear end fill plug for any signs of metal flakes also (mine looked like silver anti-seize due to the bearings delaminating/failing)
If everything sounds good your issue may be else where.
Old Nov 2, 2015 | 09:15 PM
jed1894's Avatar
jed1894
That was my origin thought and concern. It supposedly had a new tranny at 99k but I have verified that yet. I got a friend with a lift and he'll do it for free. That way I don't have an accident. Hopefully, it's some other cheaper problem. By the way, what's rear rebuild cost ?
And thanks for the post. This site is great stuff
Jed
Old Nov 2, 2015 | 09:25 PM
jed1894's Avatar
jed1894
But on the other hand, it has no vibration, slipping, etc at all. Rides good and smooth
Old Nov 2, 2015 | 09:32 PM
Rikster-7700
I believe mine was around $700 - $750 and that was just for all the bearings to be replaced in the rear end (I didn't feel at all confident in doing it myself, differentials and auto transmissions are about the only two things I don't feel good about diving into). My ring and pinion were still (thankfully) in good shape. I was hoping it was something smaller and had just replaced the u-joints, greased the splines and replaced the carrier bearing on the rear shaft a couple of weeks earlier, that obviously did not solve the problem, but at least I know the history of my rear end from the xfer case back now.
Old Nov 2, 2015 | 09:33 PM
Rikster-7700
I had no other real symptoms either except the noise if that helps?
Chris611
6.7L Power Stroke Diesel
Apr 4, 2014 09:37 AM
Pockets52
6.4L Power Stroke Diesel
Mar 29, 2013 08:25 PM
joeyd61
Mar 5, 2013 02:18 PM
BillyBob69
Mar 2, 2011 08:02 PM
Torvvald
Mar 9, 2007 11:44 PM
