'96 5.8l, No power after distributor swap
My '96 F250 recently just stopped running. I parked it after work and it wouldn't start the next morning. The problem was fixed by replacing the distributor.
Now, the engine starts and idles fine but is extremely slow to increase in RPM when the throttle is opened(meaning extremely slow throttle response), and when driving it has absolutely no power.
I have fuel pressure at the schrader valve. OBD1 test produces no codes other than a 512, and yes the battery was disconnected.
I'm not certain exactly where the timing is set, however the new distributor is in the same location as the old, and idle speed is the same. Advancing or retiring the timing does not help the problem.
I don't know which direction to go with this and need some help.
Many thanks in advance!!
Did you put the SPOUT jumper back in after you set the timing?
Do you not have a timing light? If not you can get it close with a vacuum gauge, do you have one of those? You can rent, for a fully-refundable deposit, a lot of tools from AutoZone and I think Advance too. Call and see if they'll rent you a timing light.
If the timing is off, (and most likely is, if you haven't set it since replacing the distributor) you can approach it from as many angles as you want, but the first angle should be "check the darn timing!!!"
GSchretter
10-06-2004 02:06 PM
