retarding the timing
Old Jul 8, 2006 | 01:31 PM
jaye's Avatar
jaye
I have a 71 302 w/electronic ignition in my 55; it pings when I start off fast I was told it may be the timing. The plugs are white so it is burning hot. The timing is currently set at TDC, My question is which way do I turn my dist. to retard the timing, also should I set it at a certian degree?
Thanks
Jaye
Old Jul 8, 2006 | 02:08 PM
WillyB's Avatar
WillyB
It sounds like you have other problems with the distributor. I would make sure that both the mechanical and vacuum advance are working.
My guess is that you should be sitting somewhere around 10 degrees advance at an idle. The idea is that the mechanical advance will advance the timing upwards to a max of about 28 degrees as you speed the engine up to around 3K RPM. When you crack the throttle to accelerate the vacuum advance retards the spark automatically, returning to normal timing as the vacuum returns to normal.
It is worth working on, even replacing the distributor, as you are wasting a lot of power and gas running with no advance.
Old Jul 8, 2006 | 02:20 PM
raceman351W's Avatar
raceman351W
you would turn it counter-clock wise to retard and what system do you have?
Old Jul 8, 2006 | 05:07 PM
Randy Jack's Avatar
Randy Jack
What ***** said. You should not be at TDC for idle. It does sound like a problem with the dizzy. Most auto parts stores will bench test it for you.
I personally much prefer to set the timing running. I use a Craftsman timing light that lets you set the advance you want and then just shoot the zero marjer on the harmonic balancer. Works really nice.
Old Jul 8, 2006 | 07:01 PM
jaye's Avatar
jaye
I set it at TDC when I installed it I will check to see where it is at idle tomorrow, I will also check the vacuum line.
thanks for the replys
Jaye
Old Jul 9, 2006 | 01:27 AM
packrat56's Avatar
packrat56
I have a 1971 302 in my 56, with a drop in electronic conversion. I have the timing at 6' BTDC.
Old Jul 10, 2006 | 07:55 AM
jaye's Avatar
jaye
Packrat56,
What do you have your plugs gapped at I checked my timing and its around 7-8 BTDC.
Thanks
Jaye
Old Jul 10, 2006 | 09:49 AM
packrat56's Avatar
packrat56
.32 using Autolite 45s
Old Jul 10, 2006 | 10:34 AM
jaye's Avatar
jaye
That's the same as mine
Thanks
Jaye
farmpaw
20
Mar 20, 2016 06:41 PM
Jay d
Sep 17, 2010 09:02 AM
picklebill
41
Jan 25, 2010 09:54 PM
rwlacks
Sep 1, 2008 01:08 PM
Copper93
1978 - 1996 Big Bronco
Aug 4, 2003 08:37 AM
