Slow Start
Old Oct 31, 2015 | 07:14 PM
BillDougy's Avatar
BillDougy
Slow Start
I have a 2000 Excursion with the 7.3 and I am experiencing a slow crank issue. It will always start but it always cranks slow/takes a while to start. Once it does start a good puff of white smoke will blow out the exhaust but it then runs fine. Once it is started it has no issues. I do have a couple error codes that I have been told are from the notorious loose UVCH such as injector 1 and 8 high side circuit open. Could this cause the issue? I know the batteries are good because I have had them tested and I have also swapped with brand new batteries and I have the same issue. I have also replaced the battery cable that ties the two together. Any help would be greatly appreciated because this is my old ladies truck and she will not get off my back until it is fixed and I really don't want to put it in the shop.
Old Oct 31, 2015 | 07:18 PM
Pikachu's Avatar
Pikachu
If the batteries and cables are good, that pretty much leaves just the starter . . .
Old Oct 31, 2015 | 07:21 PM
BillDougy's Avatar
BillDougy
I have had the starter tested and it checked out perfect. I forgot to mention that. I wI'll double check the frame grounds tommorow but I have no idea where they are located.
Old Oct 31, 2015 | 07:29 PM
Beechnut's Avatar
Beechnut
Buddy had the same problem....we never figured it out, was the strangest thing. chewed through batteries and constant slow start on his Excursion.
Old Oct 31, 2015 | 07:43 PM
BillDougy's Avatar
BillDougy
Man that doesn't make me feel good... I'm beginning to think I may have the same luck... with any luck someone will plow into it in the driveway lol we love the truck minus this one issue but she is an evil truck
Old Oct 31, 2015 | 09:23 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
A bad starter will chew through batteries and alternator. Put an amp meter on the starter wire and see what it is drawing under load. Check alternator output, load test batteries, check power into starter, and motor grounding. Good luck!
Old Nov 1, 2015 | 12:00 PM
crop harvester's Avatar
crop harvester
not Everybody/auto parts stores is good at testing starters/alternators,a reputable shop that performs rebuilds in house would be a good choice.
Oldanvilyoungsmith
16
Oct 2, 2017 07:35 AM
Dave O'Brien
May 6, 2013 10:42 AM
k2vailkid
13
Jun 16, 2009 02:01 PM
royzell
Apr 27, 2008 02:01 PM
jmr420
Aug 23, 2005 12:13 PM
