Eccoboost temps
Old Oct 31, 2015 | 01:15 PM
Chuckitall's Avatar
Chuckitall
Eccoboost temps
Guage is or appears normal, but what actual temperature do most of the Eccoboosts run at during normal driving? I also own a JK wrangler and it run on the hot side most of the time. Just checking what is comfortable for my F150.
Old Oct 31, 2015 | 04:49 PM
Olytlr's Avatar
Olytlr
My operating temps are usually between 200 and 210.
Old Oct 31, 2015 | 05:49 PM
Tom's Avatar
Tom
If I remember right my '13 would stay around 195 during normal operation. I've had it as high as 243 pulling something heavy up a hill, and the needle was pointing towards the warm side of normal.
Old Oct 31, 2015 | 05:52 PM
Chuckitall's Avatar
Chuckitall
Thanks, would have guessed that temp range. Mines a 15. My 14 Wrangler runs ar 212 to 226, I think that is too hot, but dealer doesn’t think so.
Old Oct 31, 2015 | 06:05 PM
Tom's Avatar
Tom
Your dealer is probably right. Different engines are designed to run at different temperatures, they're certainly not all the same.
Your Jeep has a 203 degree thermostat, and that's the temperature it begins to open, so your temps make sense. Your F150 has a 190 degree thermostat.
Old Nov 1, 2015 | 11:43 PM
highoctane74's Avatar
highoctane74
Mine stays around 195-200. Had it as high as 220 in hot summer heat towing a heavy trailer. It is very consistent.
Old Nov 5, 2015 | 08:15 AM
Chuckitall's Avatar
Chuckitall
Thanks guys
glockholiday
Nov 30, 2014 07:20 PM
toddyw
Sep 11, 2006 06:33 PM
workingdog
Aug 11, 2006 11:36 PM
Teroy
Mar 7, 2006 01:03 PM
spiritwild
Bronco II
Feb 6, 2006 09:07 PM
