Bronco II Ford Bronco II
2.9 operating temps?
Old Feb 4, 2006 | 09:52 PM
spiritwild's Avatar
spiritwild
2.9L , what temps does this engine call "normal operating" ?
Old Feb 5, 2006 | 01:58 PM
Ken00's Avatar
Ken00
I beleive the stock thermostat was a 192 or 195'f.
Old Feb 5, 2006 | 03:37 PM
spiritwild's Avatar
spiritwild
so would 210 be out of the ordinary for running temp, or is that just too hot ?
Thanks, ken.
Old Feb 6, 2006 | 08:28 PM
Ken00's Avatar
Ken00
I never measured the temperature before, anyone have an idea on this one???
What type of guage/method are you using to measure the temperature?
Old Feb 6, 2006 | 09:07 PM
plilikoi's Avatar
plilikoi
That's well below the expected boiling point of a 40% ethylene glycol solution under 15 psi, which is about 255 F.
When I measure the temp using an IR thermometer pointed in the area of the sensor behind the thermostat housing I read about 210 F after it's fully warmed up and the vehicle's temperature gauge is right in the middle of normal.
So I guess that 210 F could well be "normal".
