flushing the brake system
Old Feb 19, 2002 | 11:32 AM
shawnf150's Avatar
shawnf150
good day all
wondering if there is a proper way to flush out the brake system.
does everything,need to be apart...i.e,calipers,brake resovior.
i see alot of dirt,or contaminent in the brake resovior.
thanx shawn
1991 f150 302 e40d
Old Feb 19, 2002 | 12:54 PM
Avanti's Avatar
Avanti
Only if you are going to rebuild the brake system would I take it apart. I use a clean sucker bulb and remove all the old fluid from the master cylinder. I also wipe the inside that I can get to. Than put in new brake fluid and keep bleeding till it comes out clean. A few years back I converted a brake system to silcone on a collector car. Their I replaced everything but the metal lines & flushed the system out with denatured alcohol and air to dry them out.Than followed with new silicone fluid.Good luck on getting the bleeder screws to open.
Old Feb 19, 2002 | 03:34 PM
shawnf150's Avatar
shawnf150
thanx for the info,i will do that.
i never heard of silcon brake system before,wou;ld that be something to look at also.
i plan on keeping the truck for a long time.
thanx again shawnf150
Old Feb 19, 2002 | 11:10 PM
DrkPhanstm's Avatar
DrkPhanstm
do NOT use silicone(DOT5) brake fluid!! I made the mistake on using it in my mustang, and am about to drain it all out, tear my brakes apart, clean the seals and put DOT3/4 back in!
WilWood brakes has an interesting article on it that I'm going to try to put up
Old Feb 19, 2002 | 11:14 PM
DrkPhanstm's Avatar
DrkPhanstm
Wilwood does not recommend using DOT 5 fluid in any racing applications. DOT 5 fluid is not hygroscopic, so as moisture enters the system, it is not absorbed by the fluid, and results in beads of moisture moving through the brake line, collecting in the calipers. It is not uncommon to have caliper temperatures exceed 200° F, and at 212° F, this collected moisture will boil causing vapor lock and system failure. Additionally, DOT 5 fluid is highly compressible due to aeration and foaming under normal braking conditions, providing a spongy brake feel. DOT 5 fluid is best suited for show car applications where its anti-corrosion and paint friendly characteristics are important.
http://www.wilwood.com/products/mas...brakefluid.html
Old Feb 20, 2002 | 08:47 AM
shawnf150's Avatar
shawnf150
thanx alot with the info here.
i will do some checking and will follow up.
shawnf150
Old Feb 20, 2002 | 09:15 AM
MustangGT221's Avatar
MustangGT221
trab
Mar 5, 2013 01:51 AM
jimwilsonmasonry
Jul 6, 2012 08:18 PM
lilsis74
Aug 14, 2010 06:06 PM
slidingdelta
1983 - 2012 Ranger & B-Series
Jul 15, 2010 03:12 PM
estearly
Sep 6, 2004 01:38 PM
