93 Ranger engine swap ideas
Old Oct 30, 2015 | 01:44 PM
cowmilker08's Avatar
cowmilker08
I have a buddy who has a '93 Ranger with the 3.0L and a stick. Tall tires + plus some extra weight permanently affixed to the bed means that the little 3.0L is getting its but kicked trying to putt around on the farm.
Looking for an easier type engine swap that'll give it a little more torque down low, nothing crazy as this is just a farm service/chore truck.
Any input is appreciated!
Old Oct 30, 2015 | 09:34 PM
85e150's Avatar
85e150
Unless you need the tires for clearance, go back to a shorter tire and drive it.
Or regear it.
Repower....pita.
If you must, find a 4.0 OHV with a manual trans.
Is this 4x4? If so, find one from 4x4 and bring the TC along with it.
You must decide if you want to rewire half the truck and keep EFI. If so, bring the computer and harness from the donor too.
Or find a carb manifold for the 4.0 OHV.
Old Oct 31, 2015 | 03:30 PM
85e150's Avatar
85e150
asked and answered
https://www.ford-trucks.com/forums/1...l#post15757259
Old Nov 2, 2015 | 08:54 AM
cowmilker08
Truck is a 4x4. Taller tires are needed for clearance.
Current engine is about shot, so that why he is leaning toward an engine swap.
So it sounds like the easiest engine swap would be a 4.0 OHV, then find a carb manifold. Re-wiring half the truck is not something I'm interested in doing.
By TC you mean transfer case? Why would we need that?
I started this thread due to the lack of responses in the other thread, btw.
Old Nov 3, 2015 | 03:32 PM
Kemicalburns's Avatar
Kemicalburns
for your year ranger i would think finding a donor ranger with the motor and do a direct swap would be feasible. the 93's were not that complicated. you might find only needing to swap the computer (obvously) and the current wiring harness matching up since both motors were available for that year.
how tall are the tires by the way?
Old Nov 4, 2015 | 10:47 AM
cowmilker08
I'll have to find out, its my buddy's truck. They're not enormous.
EDIT: He just got back to me. They're 32" tall.
Old Nov 4, 2015 | 12:29 PM
Kemicalburns
yea thats a tad tall for stock gearing. even with the 4.0 he wont see a huge improvement. gearing can only fix that.
most rangers have 3.73 gearing, some did come with 4.10's also but are rare.
Old Nov 4, 2015 | 12:54 PM
cowmilker08
How hard would an axle swap be on a 4x4?
What are the torque/HP numbers on the 4.0?
Old Nov 4, 2015 | 05:42 PM
85e150's Avatar
85e150
Axle swap: Not too bad out back, just make sure the rear u-joint matchs and the brake backing plate mounting is the same.
Front--a bit more work. It's either that or change gears in the truck, and you can expect to pay about $1000+ to have that done. Gears are only about $200 per axle, but the labor to get it right plus new bearings runs up the price.
4.0 OHV was rated 155 or 160 HP, torque 225 or so.
rustyranger92
1983 - 2012 Ranger & B-Series
Feb 27, 2017 01:37 PM
CT
Oct 13, 2013 07:42 AM
Brilac
Engine Swaps
Feb 7, 2006 06:58 PM
Brilac
Dec 22, 2005 10:28 PM
seafire
Feb 21, 2005 01:21 PM
