Engine swap options?
Old Oct 9, 2013 | 11:22 AM
CT's Avatar
CT
Question Engine swap options?
I recently acquired a 1984 Ranger 4x4 with manual transmission and the original 2.8L carb V-6 engine. The frame, suspension, 4x4, and transmission seem solid for a good winter driver, but the engine is tired and using quite a bit of oil. I am wondering if there are any other engines that I might be able to find that would swap in to this Ranger? Are the late 80s 2.9L a direct swap? I don't want to have to change a lot of stuff to swap but would like to get away from the 2.8L if possible.
Old Oct 9, 2013 | 05:18 PM
f5fordgirl's Avatar
f5fordgirl
The 2.9 along with all the other V 6s are going to be injected, you really need a spare truck to get all the stuff you need. And some engines will mate your trans, some won't.
Old Oct 9, 2013 | 11:10 PM
19704X4F250's Avatar
19704X4F250
The 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 are in the same engine family. I wouldn't go with the 2.9 as the heads are prone to crack. I would swap in a 4.0. I think the intake and distributor would swap but you will have to do some research to be sure.
Old Oct 9, 2013 | 11:27 PM
Old93junk's Avatar
Old93junk
Rebuild the 2.8..........Cheapest option by far.
My 2.8 was rebuilt for under $600 in parts and some machine shop work, all the rest done by me.
Old Oct 10, 2013 | 12:54 AM
77 1/2 F250's Avatar
77 1/2 F250
Any option other than rebuilding the 2.8 are going to involve replacing the fuel system from the tank forward, since from the 2.9 on the engines were fuel injected.
The 4.0 does not even have a distributor, non of the ones I had did anyway, therefore you can't simply swap your intake and distributor onto one.
Like F5fordgirl said, the best way to do something like this is to have a complete donor truck.
I have an 88 4x4, tired 2.9 5-speed, that I use for local snowy day driving. I really don't like the lack of power (I can't even pull my johnboat 60 mph) but it would be more cost effective to buy another truck than to repower this one.
Robert
Old Oct 10, 2013 | 10:00 AM
Old93junk's Avatar
Old93junk
If you are willing to spend a little $$$ and effort, a rebuild of the 2.8 can include parts and modifications that will make it run far better than a 2.9 and very close to a 4.0 in power.
Old Oct 10, 2013 | 04:58 PM
Conanski's Avatar
Conanski
5.0 swap.
Old Oct 13, 2013 | 07:42 AM
19704X4F250
I did find an intake for the 4.0 but rather pricey......$500. Like Dave said, a rebuild of the 2.8 would be the best route.
Brilac
Dec 22, 2005 10:28 PM
daerhldgs2
Engine Swaps
Mar 10, 2005 02:06 PM
Scrib43
Aug 12, 2003 05:47 PM
Ultramagdan
Nov 6, 2001 12:33 PM
