Strange Behavior When Trying To Set Base Timing
Old Jan 21, 2017 | 09:55 AM
Conanski's Avatar
Conanski
Originally Posted by Nothing Special
Semantics. All engines with throttles have vacuum, and engines with computer-controlled ignition use a sensor to measure that vacuum. Then the computer decides how much advance to put in the timing. So there's no vacuum hose running to the distributor, but it still has vacuum advance.
No it doesn't. With the SD EFI system engine vacuum is used to determine load which is then used to calculate fueling, timing advance is calculated based on the electronic signal pulse from the distributor mounted PIP sensor, vacuum doesn't factor into it.
Old Jan 21, 2017 | 08:37 PM
Kyle Puryear's Avatar
Kyle Puryear
Moonley
The computer controls the engine. Like a computer being reset or restarted. If you change the timing the computer will remember the timing it has been running. Thus 100% changing the timing after you reset it. Back to the way the computer remembers it running before changing the timing. If you change the timing in some cases you do have to reset the computer. (adaptive memory). or it will try to run richer and try to fire at the wrong points. Advancing the timing.
often people think they need a new computer. No that is 99% not the case. (Not saying it's not the problem) but most likely not the case. I wish I had a video to post for you but I can't load it up on here.
Old Jan 22, 2017 | 10:16 AM
moonley's Avatar
moonley
That is completely not true. Spark timing is based on tables and multipliers for load, rpm, time, ECT and EGR flow. The computer has absolutely no way to know what your base timing is set at; it always assumes the factory spec base timing of 10 degrees.
Adaptive memory (otherwise known as "adaptive control" or "adaptive fueling") is for adjusting air/fuel ratio and does not control timing.
This is only your third post on the site, and there is a lot of good information here, so I recommend you read up more in some other threads to learn more about EEC operation and strategy.
Old Jan 22, 2017 | 11:26 AM
Kyle Puryear
Moonley
[QUOTE=moonley;16889125]That is completely not true. Spark timing is based on tables and multipliers for load, rpm, time, ECT and EGR flow.
EGR has absolutely nothing to do with timing at all that's exhaust back into the engine. How would that effect timing at all. Alot of people disconnect there EGR and there truck runs even better. And spark timing is based on a table graph from distributor and coil or coils.
YouTube video for you. (Setting ignition timing-efi ford\5.0(bronco & f150- how to)). This video will prove I'm not wrong. That grey plug in the video has everything to do with the computer advancing the timing. 100% the computer in some cases will in fact advance the timing.
Sorry I can not give the link to the video simply type: setting ignition timing-efi ford\5.0 (bronco & f150-how to.
That is the closest video I can find to it. And you really don't need a test light. Watch and listen.
I didn't believe it at first either but it's 100% true.
Old Jan 22, 2017 | 12:16 PM
Nothing Special's Avatar
Nothing Special
So you're saying that with a speed density EFI the timing isn't affected at all by the vacumm / engine load? So is it only affected by the base timing setting and possibly the engine speed? If that's true I'd be really surprised, because prior to SD engines always got better fuel mileage if the timing was advanced at lower load. And if that's true it seems like it wouldn't matter if you set the base timing with the SPOUT in or out because there wouldn't be any reason to change the timing at idle from base other than engine load / vacuum.
What about MAF? I'm pretty sure that's what my 49-states '97 F-250 460 has. I know for a fact that the timing gets advanced when you plug the SPOUT in at idle. It seems like that has to be related to vacuum / engine load.
And that was my point to the OP over a year ago (who never said if he had MAF or SD). His timing, at idle, with the SPOUT in , of 20 deg BTDC seemed way too low to me.
Old Jan 22, 2017 | 03:49 PM
moonley's Avatar
moonley
Yes, it does. As EGR begins to flow the computer advances the timing because the exhaust-diluted air-fuel mixture takes longer to burn. Timing is advanced in proportion to EGR flow.
That video just shows how to time an EEC-IV controlled engine, a basic maintenance procedure that is already well known. Removing the SPOUT connector is the electronic equivalent to removing and plugging your vacuum advance pre-EFI.
Old Jan 22, 2017 | 06:19 PM
rla2005's Avatar
rla2005
Prior to DPFE based EGR feedback there is no way for the computer to measure exact EGR flow, it's strictly postion feedback.
So if someone were to plug the EGR tube there is no way for the computer know. That's where some folks run into trouble with part throttle/low load detonation.
In this scenario there is no way the computer senses EGR flow, but it does advance the timing based on pre-programmed lookup tables.
My input is this based on the previous claims: Yes, the computer controls timing advance and retard function based on sensor input. There is no way it can advance the timing by 180 degrees. Cannot happen ever.
There is no need to clear the adaptive memory when or after advancing the base timing. Urban myth, IMHO.
Old Jan 22, 2017 | 06:25 PM
wtroger's Avatar
wtroger
First the distributor needs to be in right. The shutter wheel has a one smaller opening this indicates number 1 cylinder. The distributor has to be installed correctly #1 at approx 1 o'clock for the pcm to know where #1 is to control fuel injection. If this is a remote mounted icm module. Then it needs more then likely a black icm (CCD). If the Egr valve is stuck open they won't idle.
Old Jun 24, 2017 | 11:39 AM
Dmoney88's Avatar
Dmoney88
Something I just ran into
So I recently changed a few parts and while the truck started running better I all of the sudden had a cel appear with 332(erg opening not detected...which I had fixed a while back very painfully) 213 and 311(thermactor not operating or w/e)
well I was beatting my head against the wall and read this thread and another before starting the check process from beginning to end when I found out that the vacuum reservoir is a one way flow and I had miraculously hooked it up backwards and therefore was getting zero vacuum were it was supposed to go... pulled neg terminal to reset codes about to drive it now to see if they persist, I have a feeling they wont since it was after this they showed up in the first place.
That lengthy bit being said I recommend checking all your vacuum stuff including the near impossible to replace vac reservoir as that may play a role in the 213(SPOUT circuit issue, though I don't understand how) I'll post again after this test run to see if it did indeed clear it up...
Old Jun 5, 2025 | 11:11 PM
MR.REDD's Avatar
MR.REDD
2nd Gear
Oh yes. I've even watched my timing marks change before my very eyes. With the timing light pointed at the marks and my hands in my pocket L could see the timing change. Alot. I thought I was seeing things.
Rod Beauvex
Feb 24, 2014 07:40 PM
Mbrgr1
Mar 25, 2012 11:45 PM
spiderweb886
May 3, 2010 08:58 PM
handsomerob
22
Sep 28, 2007 09:06 AM
xtmanx
Sep 30, 2004 12:09 PM
