Middle seat belt? 69 F250
Did our trucks come with a middle lap belt? Feel certain mine didn't, as the seat belts were still behind the seat in factory plastic when I got it. I do want to put one in the middle, and would like a matching one, if anyone has one. Problem is mine are dang near perfect from never being out of the plastic. Anyone got a set in this dark blue color?
Thanks,
trapperjack
Thanks,
trapperjack
I had to use a large washer to be sure the loop didn't slip and really torque it down. The buckle side had the factory tab so I just stacked it and the new driver's belt and bolted them down together. (They're blue because I planed to paint the truck Harbor Blue.) They're LMC belts. Yep, my truck is filthy under the seat.
Here's what they look like from above:
I used the factory bolt holes in the upper cab corners to secure the top points. The seat cover is Red because I can't make up my mind about color. I'm leaning heavily toward Holly Green these days. I guess I'll have to choose sooner or later. When I do finally make up my mind I'll try to grab some Ford shoulder belts and ditch the LMC belts.
[QUOTE=ultraranger;15747058]You do know that that bolt is a grade-5 (3 hash marks)?
If occupants are going to be doubled up (more weight/force) on the same bolt, probably wouldn't be a bad idea to put a stronger grade-8 bolt in (6 hash marks on the head).
I'm going to go with, this is a mock up
got a pic of the 3rd point on the back of the cab?
I have some old chevy seat belts, not a problem to double up at mounting points with the right hardware. Would just prefer to have something that matched, and was correct, like ford belts. My 67 Chevy had middle belts. Not needing shoulder belts, I didn't know what a seat belt was until they made it illegal to drive without them. Were they available? an option? Or not? Thanks.
Thanks,
trapperjack
Thanks,
trapperjack
Back when I was a kid my parents had a 1969 LTD. I could swear the seat belt buckles looked just like that. See if you have a local JY that has an old 60's Ford car in it with either a front center belt like you need. Or maybe even a hardly used REAR seat belt set up. I would assume most if not all the buckles were the same back then.
Roger T. Pipe
09-16-2012 07:58 PM
