eot and ect make sure this is ok
Old Oct 24, 2015 | 07:11 PM
Mikenski's Avatar
Mikenski
Going down highway and noticed that my eot was 196 and my ect was 184, 70 mph 2100 rpm, and 45f outside driving for over 40 mins, no load on truck about 6-8 psi on turbo, should I worry, 07 f250 with 113500 miles on truck
Old Oct 24, 2015 | 07:30 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
You need a new t-stat. Don't worry about the temp splits until you get ECT to 190*f.
Old Oct 24, 2015 | 08:37 PM
KIDkiser's Avatar
KIDkiser
And then with an oem you probably won't reach 190* until summertime..now that the temps are dropping outside so is my thermostat and it's just a year old.
Old Oct 24, 2015 | 08:39 PM
MisterCMK's Avatar
MisterCMK
He will reach 192 with a good thermostat even in the winter.
Old Oct 24, 2015 | 10:03 PM
04badford's Avatar
04badford
Your temps from a cold start 40 min into the drive looks good to me you just don't want it the other way, oil will always be hotter for the most and when you stop and go again double check that the sensors ECT and EOT have dropped in temp and close to the same reading within but no more than 15 Deg spread
Old Oct 25, 2015 | 06:57 AM
Mikenski's Avatar
Mikenski
Thats the way it was while running it got to the most of 14 apart eot being hotter, but when I turned truck off went to store and came out eot droped to same as my ect,
Old Oct 25, 2015 | 07:27 AM
acf6's Avatar
acf6
Just curious but what gears do you have? I'm at 2k rpm at 80
Old Oct 25, 2015 | 07:39 AM
bismic's Avatar
bismic
After a 24 hour "cold soak" (ie no engine starts), what are the EOT and ECT values?
Old Oct 25, 2015 | 09:03 AM
Mikenski's Avatar
Mikenski
3.73 gears, and at 2k rpm I'm doing 70, and I'll let you know tomorrow after 24 hr, when I go to work
stangclassic66
Aug 5, 2014 07:22 PM
frenchy750
Jan 3, 2011 03:45 PM
david00f150
Dec 9, 2010 08:35 AM
DJdemon6696
Sep 24, 2007 04:30 PM
BuickTurbo
Sep 20, 2005 09:25 AM
