Thermostats
Old Sep 19, 2005 | 05:17 PM
BuickTurbo's Avatar
BuickTurbo
Thermostats
Is there a lower temp stat than the 190-195? Where can I get me one!?
Old Sep 19, 2005 | 05:34 PM
wlihntr's Avatar
wlihntr
you dont want a lower temp stat. in fact many people put 203* stats in to inprove engine performance:
WHY IS 203* BETTER THAN 195*?
Diesels run most efficiently at approximately 200*. A 195* thermostat will start to open at approximately 165*-170*. The Powerstroke has such an efficient cooling system, that this low flow when the thermostat is slightly open is normally enough to keep the engine cool. The downfall to this is that the engine -- when our trucks are not under load --never begins to reach its optimal operating temperature. Our 203* thermostat begins to open at 185*. This brings the operating temps up from about 170* to about 185*. This is closer to the operating temperature range that is preferable in our trucks for optimal efficiency.
When our trucks are under load and are producing higher combustion temperatures the 203* will allow the engine to run even closer to its optimal operating temperature. If the truck is under load and reaches the 203o setting, the thermostat is then fully open. This means you are at the maximum coolant temperature that the truck will reach. Your maximum temperatures are only a few degrees higher than in stock configuration, but these are degrees that you want for better performance. The best benefits come when the same truck is under a light load and would have a hard time reaching this optimal temperature. As stated above, you will never reach this optimum temperature with the stock 195* thermostat. The end result of installing the 203* thermostat should be slightly better fuel economy, less smoke, and maybe a few extra "ponies" to go along with it.
if you are having engine cooling problems than something is wrong
if you are looking for more power, once again a turbo diesel is not like a turbo gas engine
Old Sep 19, 2005 | 05:55 PM
BuickTurbo's Avatar
BuickTurbo
Exactly what I needed to know, thank you.
Old Sep 19, 2005 | 09:05 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
CAUTION! The 203* t-stat at the local dealers/parts houses is for the 94-97 engines and will not work correctly in your 2000.
Old Sep 19, 2005 | 09:42 PM
magnum300's Avatar
magnum300
get a new housing when you get the t-stat, old ones are usually very hard to get to seal agian
Old Sep 20, 2005 | 08:01 AM
rmilchman's Avatar
rmilchman
Make sure when you buy the 203 that it is made for the Ford and not International. The Ford version will be longer.
Old Sep 20, 2005 | 09:19 AM
BuickTurbo's Avatar
BuickTurbo
WLIHNTR.......where did that information come from? I am curious. I certainly do not doubt the info. Also, where would one procure said 203? We have a Ford Truck house here in Dallas that I use for parts.
Old Sep 20, 2005 | 09:25 AM
wlihntr's Avatar
wlihntr
...dieselsite.com is where the info came from and you can buy one there
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
