Options for blinker lever
Old 10-26-2015, 03:36 AM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
3"????? I guess some guys would think that's long!!!!.. ha ha ha ha ................ ....... but seriously that must of been modified by someone as a joke or something.. any wrecking yard should have a factory one that is a lot closer to being right
Old 10-26-2015, 09:58 AM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
I wish I still had access to a machine shop. I could make some custom levers and shift ***** and sell them off. I've made some levers and ***** in some of my previous projects to add that extra custom touch.
Old 10-26-2015, 10:24 AM
orich's Avatar
orich
orich is offline
Geez, I know the lost feeling when you have a place to do some type of repair at hand any time you have a need.
Then take it all away and you feel lost or like having your hand tied behind you and can't do ***** any more
Orich
Old 10-26-2015, 11:20 AM
crazed87bronco
Orich
Yea It was great to have access to all that anytime I wanted. I did CNC maintenance but I moved out of state and my new job isn't in the machining field. Once things get settled in i want to get back into CNC maintenance again. I hate having to go pay for any machine work I need done now and most shops turn me down for the simplest things. so that's been contributing to why my truck isn't as far along as I hoped it would be by now.
Old 10-27-2015, 10:45 AM
mjunk1's Avatar
mjunk1
mjunk1 is offline
Seems to me this would be about the easiest customizing fabrication known to man. Go to Lowe's and get a piece of mild steel dowling rod, cut it to length, shape whatever you want on the end and epoxy it on there and run a die over the other end to thread it in there. Viola! You could put just about anything you want on the end (a shell from a .357, a 6 sided die, etc, etc, etc) and have something to talk about.
Old 10-27-2015, 11:33 AM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Originally Posted by ultraranger
No more effort than it takes to lift your fingers off the steering wheel and push the signal lever either up or down, it ought to be perfectly legal to ****** someone out of their vehicle and beat the crap out of them, for not signaling.
--there's a lot of non-signalers around here and it's really annoying.
Come on Steve......they don't have time to use that silly old turn signal lever, they're to busy texting.
Old 10-27-2015, 11:52 AM
ultraranger's Avatar
ultraranger
ultraranger is offline
Originally Posted by Tomahawk
Come on Steve......they don't have time to use that silly old turn signal lever, they're too busy texting.
That's probably true and now that some vehicles will automatically brake if you run up on someone, it means you can pay even less attention to driving and focus more on important things like texting and updating your Facebook status.
Old 10-27-2015, 12:05 PM
mjunk1's Avatar
mjunk1
mjunk1 is offline
Updating my Instatweet and Facegram isn't easy when you have a manual tranny!
Old 10-27-2015, 12:43 PM
orich's Avatar
orich
orich is offline
2x Should not be all the hard to find something 5.5" long OEM length
Orich
FX4-2007
2004 - 2008 F150
08-16-2016 09:09 PM
Traxxis
01-24-2005 08:28 PM
War_is_my_Shepherd
Garage & Workshop
07-23-2004 11:53 AM
460f250
Paint & Bodywork
03-29-2003 10:37 PM
BigBrownTruck
01-18-2001 07:44 AM
Quick Reply: Options for blinker lever
