4x2 dually.
Old Oct 23, 2015 | 09:24 PM
1BFT's Avatar
1BFT
4x2 dually.
I am looking to buy an f350 4x2 dually but I cannot find one anywhere. It seems that all in-stock f350s are 4x4. Do any of you drive a 4x2 dually and did you have to special order it?
Old Oct 23, 2015 | 11:23 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I ordered mine 2013 but I also wanted a 6.2 with 4.30 gears so it made it even harder to find.
Denny
Old Oct 24, 2015 | 08:25 AM
senix's Avatar
senix
Most are 4x4. Easier to get in and out of campgrounds and wet areas with a trailer.
I think you can get a 4x2 with a e-locker. Don't know if that is an option with a DRW.
Old Oct 24, 2015 | 08:38 AM
Just Strokin's Avatar
Just Strokin
I special ordered mine. That way I was able to get what I wanted on it. Most trucks on the lots have minimal equipment or like you found, 4x4.
The 6.7 dually comes with 3.73 and i added the limited slip differential.
I don't think you always need nor have to have a 4x4 with most RV areas now days. I have no need for a 4x4 even in winter.
Old Oct 24, 2015 | 10:00 AM
rvpuller's Avatar
rvpuller
I've been pulling 5vers sense 1987 and never used a 4x4 and that excludes boonbocking in Colorado and Minnesota.
I've found that the Ford DRW with limited slip is a great rear end, the Dana LS slips very little before I it engages.
Denny
Old Oct 24, 2015 | 04:30 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
We in Michigan, at least where we live. Don't get plowed out very well during the winter.
So we need 4X4 several times a year around here.
Old Oct 24, 2015 | 06:15 PM
wingedone's Avatar
wingedone
I ordered mine in March and received in May 2013, I wanted specific things and no way it would be available anywhere.
I just put my trailer into covered storage yesterday, the truck is in the garage until Spring.
Old Oct 25, 2015 | 12:06 AM
1BFT's Avatar
1BFT
Thanks for all the replies. Living in Washington state I have always had a 4x4 because of the winters but now I intend to be a full time RVr for the forseable future I don't intend to be anywhere that will require 4x4 also I hate the turning circle of my 4x4 f250. I am looking to better match my truck to my 40 foot Landmark Mesa RV so I guess I'll have to look at ordering one. If you spec one for a factory build how do you go about negotiating the final price?
Old Oct 25, 2015 | 05:11 AM
Just Strokin
I went to NADA and spec'd the 2016 Fusion I ordered in September. Their figures were the same as the dealer invoice I was quoted by the dealer. The only added charges not shown on NADA was a fuel and advertising charge.
NADA
Old Oct 25, 2015 | 06:49 AM
bigredtruckmi
Veteran: Navy
Your comment on turning radius. We had the same problem. Our new truck has the max tow pkg. this set out the front wheels by a lot. This,gives us more turning deg on front tires. This truck turns inside the radius of the big red. It makes the tires squeal it's turning so short when in parking lot.
Old Oct 25, 2015 | 06:54 AM
senix's Avatar
senix
One thing to consider (not that I am trying to change your mind) is that modern 4x4's don't take much from the fuel economy when not in operation.
Old Oct 25, 2015 | 09:05 AM
Irelands child's Avatar
Irelands child
I'm an advocate of a 4x4 DRW or SRW after towing for years with a 4x2 SRW F350. Besides getting buried in mud and sand or backing up a slippery grassed incline to a site in more then a few CGs, that truck would spin the rear tires on a wad of frozen spit even with Ford's version of a traction device of that bygone era. Heck, even our seasonal CG has a road that 4x4 works best when wet. So far with exception of costing more dollars to buy and a slim chance of added maintenance, I see no downside for a 4x4. But of course, there are choices and if the OP wishes to go that way, there are few used and probably neven fewer new 4x2 duallys on dealer's lots.
Old Oct 25, 2015 | 09:42 AM
rvpuller's Avatar
rvpuller
I've had Fords version of limited slip rear ends and they aren't much better than a one wheel wonder but the Dana 80 is a hole different animal, it really works.
Denny
Old Oct 25, 2015 | 09:43 AM
69cj's Avatar
69cj
If you only need the 4x4 once or twice a year it has paid for itself.
Old Oct 25, 2015 | 10:04 AM
wingedone's Avatar
wingedone
There are a couple of advantages with the 4x2 in addition to those noted. No front end death wobble and no need for bags, etc to level up the truck under load.
